cleaning under the hood
Discussion in '4 Cylinder' started by SupremeDeluxe, Jul 6, 2011.
  1. Jul 6, 2011 at 8:57 PM
    SupremeDeluxe
    SupremeDeluxe [OP] Member
    Virginia
    Coma
    Every spring season, the pollen becomes a nuisance to the city I live in. I just opened the hood of my truck and it is filthy. I want it to look new again.
    My question is, is it okay to high pressure wash the engine under the hood? I used to drive a Celica with a Cold Air Intake and I ended up hydrolocking the engine which concerns me about spraying the dirt off the engine with high pressure water. I would like to clean the outside of my engine really soon but thought I should ask if anything under the hood can get damage from the high pressure washer. Thanks.
  2. Jul 6, 2011 at 8:59 PM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Simple green+pressure wash+let dry+CD-2 eng cleaner= Like new!
    I spay my eng all the time no problems just be careful around the
    intake and you should be good!
  3. Jul 6, 2011 at 9:11 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
  4. Jul 7, 2011 at 6:32 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've heard others say they spray with the engine running but I wouldn't do it while the engine is hot. Hot engine + cold water can equal a cracked head or block
  5. Jul 8, 2011 at 5:27 PM
    little red
    little red Well-Known Member
    Central GA
    PreRunner SR5
    Been cleaning my engine compartment for years with greased lighting and a light mist from a hose. After it dries I apply a product from Gunk called Acra Seal which is a plastic spray and ignition sealer. Spray all the rubber and plastic parts and it will look like the day it was first sold. (just don't spray the drive belt or it may squeak)
  6. Jul 8, 2011 at 5:38 PM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    engine degreaser, simple green, and a pressure washer works everytime.
  7. Aug 19, 2015 at 3:47 PM
    bluesttape
    bluesttape Well-Known Member
    Denver
    '14 TRD Sport DCSB
    Debadged 3in Lift KO2s 275/70/17 OEM Stock Rims w/TRD Center Caps TRD Cap-Back Exhaust Avid Light Bar A.R.E. CX Cap OEM Nerf Bars OEM Rack on Cab Thule Rack on Cap WeatherTech Floor-liners WeatherTech Vent Visor CoverKing Seat Covers Chicco Keyfit 30 :-) Clifford 5806x Alarm & Remote Start LED Replaced (dome,map,flasher, reverse, & parking) Salex Organizer in Glove Box & Center Console Fully Tinted 12in ClearBra
    So happy to hear I can spray it down... What should I avoid spraying?
  8. Aug 20, 2015 at 3:40 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    IMHO power washers are a bad idea under the hood. Yes most modern electrical connections are designed to keep water out, but only at pressures that would normally be seen under the hood. No electrical connector can keep out the pressure of a power washer. If you must, be careful and you *should* be OK but you may end up with a sparkling engine that won't run. You have been warned. I wrap the alternator with a few plastic grocery bags and rubber bands, then very carefully use the garden hose on everything else. I'm really careful around the air injector intake and the battery. Wash it cold and run it after to dry off. Hope this helps you.
    bluesttape likes this.
  9. Aug 23, 2015 at 3:53 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    Avoiding spraying any of the pulleys with that pressure washer...
