cleaning windows with and without tint
Discussion in 'Detailing' started by syds4x4, Jun 30, 2010.
  1. Jun 30, 2010 at 5:07 AM
    syds4x4
    syds4x4 [OP] Member
    S.K.
    Los Angeles
    mine's blk syds'is purple
    debadged,shell,blacked out tail lights tint,security sys,nav,dvd,bluetooth,...
    cleaning w/without tint
    paper towels,newspaper,microfiber,clean rags
    1 oz dawn 4 oz rubbing alcohol 59 oz water makes a 1/2 gal of cleaner
    safe on tint
    and for the film side plastic polish (Plexus)
    this will protect the mylar coating on your film(scratch resistant coating)
    for best results Never clean windows in direct sunlight
  2. Jun 30, 2010 at 7:01 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Sorry, but this makes no sense. You claim that the mixture is safe on tint, but in the next line, you claim that you use plexus on the tint.
    How about just using a microfiber glass towel and stoners invisible glass. Damn near unbeatable combo and not nearly the trouble that you go through.
  3. Jun 30, 2010 at 7:44 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I use vinegar and a paper towel, inside and out. Have been doing so since 07 windows and tint look fine.
  4. Jun 30, 2010 at 7:46 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    any window cleaner will work as long as its ammonia free
  5. Jun 30, 2010 at 9:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    ^ Thats whats important.
  6. Jun 30, 2010 at 9:59 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    what this dude said!
  7. Jul 1, 2010 at 5:38 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I was amazed at the results using vinegar. Even gets the water spots off the outside with virtually no effort.
  8. Jul 1, 2010 at 10:37 PM
    syds4x4
    syds4x4 [OP] Member
    S.K.
    Los Angeles
    ok let me explain dawn,detergent for cleaning,rubbing alcohol,for anti streaking and water makes a solution mild enough for everyday use inside and out even for aftermarket tint/film and factory privacy glass (factory tint).
    For aftermarket film (tint)I use Plexus,a plastic restorer/protectant/cleaner/release spray because of the effects of a just cleaned surface (squeeky clean) will have an ill effect on your film and the rubber seals ,and thus have a tendency to grab and pull seals and film plus wear and tear on window regulator, your windows seal from the inside out, most of your seal is on the inside.
  9. Jul 1, 2010 at 11:28 PM
    syds4x4
    syds4x4 [OP] Member
    S.K.
    Los Angeles
    (window tint ) aftermarket tint/film
    (privacy glass) factory tint
    plexus will help to preserve the tint/film from peeling/failing and ...
    dry silicone release spray on your window seals once a year will also make your regulator and window/tint last. "an ounce of prevention ..."
