Clear a single code to pass inspection
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, May 27, 2023.
  1. Oct 19, 2024 at 1:40 PM
    Brooky816
    Brooky816 Well-Known Member
    06 Tacoma SR5 Prerunner double cab
    None
    Thanks dm93.I didn’t mention but I’m not sure cluster is bad.I figured this out on a fluke.I thought for sure I had a bad speed sensor on transmission.I hooked up scan tool and can erase check engine light.Well,I went riding around with tool plugged in an reset code.I shift transmission in neutral just coasting and light goes off and stayes off.Hmm,well I bought new speed sensor
    and swapped out and light still comes back on.Speed odometer works but sometimes the cruise control won’t engage.
    Maybe I should just jump the wire in the cluster.Thanks any help would be appreciated!
  2. Oct 19, 2024 at 9:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That's probably due to how the monitor runs for P0500, auto trans trucks do not use a vehicle speed sensor. Monitor vehicle speed in scan data, if it drops out but your speedometer keeps working it's most likely the cluster and the bypass would likely fix it.
    See the post below for description of the P0500 code.
    https://www.tacomaworld.com/threads/2nd-gen-information-diagnostics.784008/#post-28042157
  3. Oct 20, 2024 at 11:20 AM
    Brooky816
    None
    Ok Thanks man.Im going to try the bypass thing soon!
  4. Oct 22, 2024 at 11:35 AM
    Brooky816
    None
    Ok, Do you have to reset check engine light or does light automatically go away?I hooked up and
    light still on? Thank you!
  5. Oct 22, 2024 at 11:55 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It will eventually clear on it's own if you fixed the issue but it would be faster to just clear the codes with a scan tool.
  6. Oct 22, 2024 at 1:21 PM
    Brooky816
    None
    Ok Thanks man.
  7. Oct 22, 2024 at 7:38 PM
    Brooky816
    None
    Hey Thanks again Dm93.Cleared code and so far so good!Cruise control works too!Been driving
    around for almost a year with check engine light before I found this post.You know a lot about
    Tacomas Lol!
    Dm93 likes this.
  8. Feb 27, 2025 at 11:55 AM
    soberirishman78
    soberirishman78 New Member
    05 prerunner
    I Just tried this and it worked perfectly to fix cruise control and after clearing my p0500 code it has not returned, I did make a mistake and clipped 6 and 19 and just spliced them, so my speedometer stopped working, ill have to go back in and splice the 6 wire back in, but thank you all for the solution.
  9. Feb 27, 2025 at 3:12 PM
    soberirishman78
    05 prerunner
    fixed it during lunch, made a quick video for it, https://youtu.be/GUJPxSmjT4Q everything works now after resplicing. thanks again everyone
