Clear Coat on Trail Wheels
Discussion in 'Detailing' started by Unchained 5150, Nov 29, 2017.
  1. Nov 29, 2017 at 8:05 AM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Just got some new Take Off's there is some light scratches in the Clear on them. Can't feel them but in the right light you can see them. They are not on the truck yet, anything someone could suggest I can use to blend it in and then seal them with?
  2. Nov 29, 2017 at 2:23 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I’d try some Megs ScratchX on a foam pad by hand. Go light on the polish so not too much lubrication preventing the abrasives from going to work. And remember that clear coat can be very thin on edges.
  3. Nov 29, 2017 at 2:24 PM
    NMTrailRider
    New Mexico
    Seal them with anything you want. ScratchX doesn’t have a wax/sealant component.
  4. Nov 29, 2017 at 4:07 PM
    wmb67
    wmb67 Well-Known Member
    Boston
    09 Dbl Cab Off Road MGM
    Hey Rick,
    Throw up some photos if you can.
    Are they painted/clearcoated?
    Assuming that they are:
    Since you can't feel the scratches, you should be able to remove them with compound and polish. You could use a random orbital polisher on the wheel faces. If the scratches aren't accessible with a polisher (like on the sides of the spokes), you can use the compound and polish by hand.
    Apply and work in some polish with a microfiber towel,wipe away the residue and check your results. It may take a couple applications.
    Start with the least aggressive polish first, thereby saving as much clear coat as possible.
    If a finish polish isn't yielding good results, use a more aggressive compound, then follow that up with a finish polish.
    Harpolith's suggestion of Megs ScratchX is good and available at most auto parts stores. His suggestion to seal them after polishing is a good one also.
    If it was me, I'd polish the wheels and seal them with a ceramic coating. The coating repels dirt and grime and makes cleaning them much easier.
    This is what I use on both my paint and wheels- Here is a photo of my truck from a couple years ago.
    Synergy001 and NMTrailRider like this.
  5. Nov 29, 2017 at 4:15 PM
    NMTrailRider
    New Mexico
    I’ve been curious about that DG enviroshield. Glad to hear you had luck with it.
    FYI the ScratchX is a super-micro abrasive (“SMAT” in Megs jargon). It’s a non diminishing abrasive. So you can stop anywhere in the buffing cycle. Tailor the “cut” with your applicator selection and pressure. Foam and light touch to start. If you need more cut, go to microfiber.
    Remember you can really cut through clear by hand with pressure focused on a finger tip (creating “valleys”). Just be smart and you’ll be ok. Good advice above. Start easy, go with more gusto only if needed.
  6. Nov 29, 2017 at 5:21 PM
    wmb67
    Boston
    Harpolith - I like the Enviroshield. It lasts about a year, is user friendly and is reasonably priced.
    Unchained- Ideally these rims are not on the vehicle yet. It is much easier to polish and seal while they are off the truck.
  7. Nov 29, 2017 at 5:23 PM
    Unchained 5150
    Rick
    Auburn Ma
    Fuck how did I not get one of these fucking notifications? I used Ultimate Compound and it worked great. Finished them with some Blackfire Sealant and they look sweet.
    NMTrailRider and ace96 like this.
  8. Nov 29, 2017 at 5:24 PM
    Unchained 5150
    Rick
    Auburn Ma
  9. Nov 29, 2017 at 5:28 PM
    Unchained 5150
    Rick
    Auburn Ma
  10. Nov 30, 2017 at 5:59 AM
    Unchained 5150
    Rick
    Auburn Ma
    How often does that Ceramic Coating need to be applied?
  11. Nov 30, 2017 at 11:29 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Typically the coatings I have seen for wheels usually last a year. I don't think my 2 year paint coating lasted that long on the wheels. I am assuming due to the heat generated.
  12. Nov 30, 2017 at 11:47 AM
    NMTrailRider
    New Mexico
    McKee's 37 (Autogeek) has a wheel coating for $35. You won't find a wheel specific coating for less money. Their paint coating is $45. Also the cheapest on the market. I've not used either, but they get great reviews on the forum.
    ace96 and Unchained 5150[OP] like this.
  13. Nov 30, 2017 at 11:51 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    @Unchained 5150
    When are you gonna get these bad boys put on the truck Rick?! Cant wait to see how it looks!:D
  14. Nov 30, 2017 at 11:55 AM
    Unchained 5150
    Rick
    Auburn Ma
    Been waiting a week now for the black lugs/locks, sensors. And the TRD Pro Red Center Caps don't come until next Tuesday.
    BassAckwards likes this.
  15. Nov 30, 2017 at 11:59 AM
    Unchained 5150
    Rick
    Auburn Ma
    First pic is how they sit in the garage, and the secnd pic is the one Gunny from Camelback sent me with the 2017 TRD Pro Center Cap in. Definitely going with the red as it will accent the truck better.
  16. Nov 30, 2017 at 11:59 AM
    BassAckwards
    Ill be waiting to check em out! :popcorn:
    Do you know if you have to mod the center caps any to get them to work?
  17. Nov 30, 2017 at 12:00 PM
    BassAckwards
    :drool: Gonna look sweeeet!
  18. Nov 30, 2017 at 12:00 PM
    Unchained 5150
    Rick
    Auburn Ma
    No mod needed just took all the round snap rings out the old Center Caps and they will fit in the new one's
    BassAckwards[QUOTED] likes this.
  19. Nov 30, 2017 at 12:01 PM
    Unchained 5150
    Rick
    Auburn Ma
    I'm hoping as the current 5 Bronze Beadlock's are already sold with the tires
  20. Nov 30, 2017 at 12:02 PM
    BassAckwards
    You gonna find a single wheel for your hitchgate so they all match? I think i remember reading elsewhere that you picked up a set of 4?
