Clear Coat Suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpacemanSpiff, Feb 20, 2025.
  1. Feb 21, 2025 at 9:36 AM
    TacoTuesday1
    SD CA
    If it was me and I knew a painter like that:
    1. I'd change to something like smooth desert tan Durabak
    2. I'd probably have to assist in the prep to reduce labor cost and time and determine if any bodywork beyond sanding is needed, like leveling
    meaning taking off anything that has to come out of the way for painting
    the factory colors are not special or worth anything. And Durabak is potentially less work for what is likely a better looking and stronger result.
  2. Feb 21, 2025 at 11:11 AM
    SpacemanSpiff
    SpacemanSpiff [OP] Well-Known Member
    James
    08 TRD Off-road
  3. Feb 21, 2025 at 11:27 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    $400 is a scuff, mask & shoot, tops. You know what they say, "If it sounds too good to be true....." I'd be a little hesitant. As someone who had quite a bit of experience in this field in my younger days, and delivered paint & supplies to shops in my retirement, I dunno. I will say to expect as least $1K + minimum for supplies, probably closer to 2. And that's not near top shelf stuff. Good luck OP, I'll be interested to see how this turns out.
