Clear Headlight protectors available?
Discussion in 'Lighting' started by snappa, Dec 28, 2011.
  1. Dec 28, 2011 at 4:17 PM
    snappa
    snappa [OP] Snappa
    Rhode Island
    2011 PreRunner Access Cab
    First, thanks in advance for any replies.
    2011 PreRunner, Ext. Cab, 2WD, V6, Auto.
    I am hoping to find CLEAR headlight protectors specific for my Tacoma similar to what I have on my 2008 Honda GoldWing GL1800 since new:
    http://wingstuff.com/pgroup_detail/...800/290_goldwing_accessory_front/des/?page=16
    They are shaped to the exact dimensions of the GL1800 lens and attach via super velcro (sic) tabs, remove easily, clean easy and are inexpensive to replace although I have never had to do so. They don't fall off or blow off at high speeds or in crosswinds.
    So, can the collective here guide me to a source, if they are available? Again, thanks in advance.
    Snappa
    "Above all else, ride safe."
  2. Dec 30, 2011 at 10:22 AM
    BBYE V8
    BBYE V8 Please keep TW beautiful: search & stay on topic
    Brian
    StL, MO
    07 AC 4x4 2.7 5sp SR5
    Do you not like the clear adhesive type of headlight protection? They are far cheaper, nearly impossible to see them once installed, and easy to install/remove/replace. Cutting them yourself is easy, but you can also buy pre-cut versions. Go to www.griotsgarage.com and search "headlight" if you want to see what I'm talking about (but keep in mind they can be found for less $ than Griots)
