clear rock guards gone bad over time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by novataco, Feb 24, 2022.
  1. Feb 27, 2023 at 11:45 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Mine look bad too but because the clear coat on the fender flares is peeling so badly I hardly notice it.
  2. Feb 28, 2023 at 9:22 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Accidentally hitting them with a pressure washer will also remove them. :homer: I don't recommend it though.
  3. Feb 28, 2023 at 6:38 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    That's why I changed mine out. Trying to get the stain from red clay off and pretty much caused them to be trashed. Really didn't think that little electric Walmart pressure washer could do that.
  4. Mar 2, 2023 at 7:14 AM
    novataco
    novataco [OP] Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    Follow-up. I tried several methods. The easiest was heat it up with a hair dryer, a heat gun, a propane torch, it doesn’t matter, just warm it up. Use a plastic razor/scraper, the kind you get at an auto store that has the replaceable plastic blades. Another poster in this thread recommended that. That is the best tool because of the fine plastic edge. It comes off pretty quick. If you scrape a little paint off, dab it with a dupli-color paint pen. The auto store has it in your paint color, for example mine is silver-streak and they had it in stock. Then clean it off and put the new rock guard on. This technique made it go pretty quick, I think about 20 minutes per side.
