Clearing fault codes: dealer vs others
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mog, Jul 31, 2017.
  1. Jul 31, 2017 at 8:50 AM
    Mog
    Mog [OP] Active Member
    Brandon
    Gilbert, Arizona
    05 DC TRD Sport 4x4 Silver
    Is the dealer able to clear fault codes in a way that is different than what AutoZone/local mechanic shops can do? I am specifically interested in clearing an airbag light that I have on my dash. I installed a head unit and turned the ignition on to see if it worked prior to plugging in all the other components, and I am thinking this may be the cause of my crazy electrical issues.
    Dealer wants $130 to clear these codes from the computer, I'm willing to give this a shot if it has a chance of working!
  2. Jul 31, 2017 at 8:53 AM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Did the same thing once and all I did was unplug the battery and airbag light went away
    boogie3478 likes this.
  3. Jul 31, 2017 at 9:10 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    This. If it's a serious code where something is actually wrong with the truck then the code will pop back on. Otherwise you should be in the clear.
    TacoJova[QUOTED] likes this.
  4. Jul 31, 2017 at 12:36 PM
    Mog
    Brandon
    Gilbert, Arizona
    I have unplugged the battery many time without any luck, most recently had a buddies shop pull the code and it was a passenger occupancy airbag sensor code.
    Just FYI, the airbag light comes on, radio completely dies, fob stops working, and dome light all stop working for about 10-30 mins each day, then magically all come back on.
  5. Jul 31, 2017 at 12:52 PM
    TacoJova
    Central Oregon
    Then I think you have a bigger problem and I don't think clearing the codes will help
    cliffyk likes this.
  6. Jul 31, 2017 at 12:53 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    You don't need to be here on TW , you need a exorcist
  7. Jul 31, 2017 at 12:54 PM
    igno1tus
    A ultragauge or scangauge would clear the codes
    Avsfreak18 likes this.
  8. Jul 31, 2017 at 3:12 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Sounds like a short. Loose connection maybe?
  9. Jul 31, 2017 at 8:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sometimes the dealer does need to clear an SRS Airbag Fault for the reason you stated... But this statement:
    " Just FYI, the airbag light comes on, radio completely dies, fob stops working, and dome light all stop working for about 10-30 mins each day, then magically all come back on."
    Makes me think you have other issues triggering the SRS Fault. Go back in and reverse all that you did installing the stereo and see what happens then. I think you have something connected incorrectly or other wiring issue.
    TRDSport10 likes this.
  10. Aug 1, 2017 at 6:42 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    ^^^ This is exactly what I was thinking as well. If before the stereo install you didn't have an issue, its something in the way you wired it. Hook the factory stereo back up with your battery disconnected. Once everything is plugged back in including the plugs for the factory clock etc, hook your battery back up and see if that clears the lights.
    If you still have an Air Bag light on, you're going to need to scan it in order to figure out what fault code is being stored. An ODB Scan from your local parts store most likely will not pull the code nor allow you to clear it.
    With that being said, if you have a laptop with a windows 64 bit Operating System on it, you could go the route of installing TechStream and using a Mini VCI cable that you can get off Amazon: https://www.amazon.com/gp/product/B01M1R409L/ref=pe_316110_248493510_em_1p_0_ti Installing TechStream is a little tricky to install but if you want to go this route and save a bit of money, you can PM me and I'll help walk you through the install process.
  11. Aug 1, 2017 at 7:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    Any OS? Any better/easier than another?
  12. Aug 1, 2017 at 11:09 AM
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Windows XP 64bit and up will work. I did it on windows 10 and there shouldn't be that much of a difference between 7, 8 & 10. XP might be another story but I have not used XP in years.
    Here is a link to an install guide: http://www.ft86club.com/forums/showthread.php?t=73034
    Just make sure and follow it step by step and you can't go wrong. The key part to it is modifying the registry which is easy with one the provided files in the drop box link. Again if you or anybody wants to attempt this, send me a PM and I'll do what I can to help. It was a tremendous tool to have when I was diagnosing a rear wheel speed sensor issue.
