Clearing up swirls on dash/speedo plastic?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco dv, Jun 6, 2024.
  1. Jun 13, 2024 at 8:56 PM
    Grimble27
    Grimble27 Well-Known Member
    Washington
    '23 White Tacoma TRD OR
    Another vote here for Screen Protech. Had it on my Tacoma and it was awesome.
    edit: wrong forum ‍♂️
  2. Jun 14, 2024 at 3:21 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    You need a baby diaper for polishing. Cheap Microfiber towels scratch. I used some fine plastic polish and a baby diaper and its crystal clear.
  3. Jun 24, 2024 at 12:05 AM
    PooTaco
    PooTaco Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
    The polish definitely helped mine, but the deeper scratches are still there.
    I can live with it....
  4. Jun 24, 2024 at 4:13 AM
    Ole No. 1
    Ole No. 1 Well-Known Member
    2023 TRD OR DCSB 4WD
    ScreenProtech hides the scratches well. You still have to be careful when cleaning though as it too can scratch.
  5. Jun 24, 2024 at 10:59 AM
    Taco dv
    Taco dv [OP] Well-Known Member
    2020 Tacoma TRD off-road
    It doesn’t bother me until the sun shines on it and it looks like crap.
  6. Jun 24, 2024 at 11:15 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Anything that you will do to try to remove the scratches will make the scratches worse.
    You have two options, learning to deal with it or buying a new one.
    The plastic is incredibly prone to scratching and attracting dust and sucking dust behind the instrument lens.
    It gets worse when somebody at a dealership or car wash doesn’t realize this and cleans it and when you get the truck back when the light shines on it you can’t even see the instruments anymore.
    edit: there are apparently part numbers for the silver one and black one, I ordered the black one but got the silver one. The dealership said the black one wasn’t available and they were just shipping the silver one if you ordered the black one. I don’t know if this is true.
    MGMDesertTaco likes this.
  7. Jun 24, 2024 at 11:36 AM
    CSVT
    CSVT Well-Known Member
    Ohio
    2021 TRD Pro
    Screen Protech vote again here too. Dont bother with polishing agents, thats a huge mess with less than desirable results.
    Slap a screen protech on and 97% of all the scratches will be gone after that. 5-10 min install. screenprotech dot com
    Taco dv[OP] likes this.
  8. Jun 24, 2024 at 11:48 AM
    Taco dv
    Can it be easily removed if needed?
  9. Jun 24, 2024 at 12:00 PM
    CSVT
    Ohio
    2021 TRD Pro
    I would say probably not, it bonds pretty solidly. Think phone screen protector with better adhesive once it cures. You'd probably need some heat & some patience if you ever really wanted to get it off.
    I think replacing the actual clear plastic cover of the dash is something you can get from he dealer stand alone for $50 or something if you royally screwed up the installation somehow.
    That said, its a very forgiving install. Spray plenty of soapy water, squegee, and take your time. You can peel it back indefinitely to remove hair, dust, or bubbles while its curing as long as you keep spraying the soapy application bottle solution on it
    Taco dv[QUOTED][OP] likes this.
  10. Jun 24, 2024 at 12:11 PM
    Taco dv
    Thanks. Just out of curiosity, how do you replace the OEM screen? Is it difficult?
  11. Jun 24, 2024 at 12:15 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    It’s easy, but it is a bit of a pain in the ass.
    You have to pull off all the dashtrim pieces surrounding it.
    Then you have to unscrew the entire instrument cluster.
    Then you have to unplug the instrument cluster.
    Then you have to unscrew the lens from the back of the instrument cluster.
    And you have to install the new lens, screw it in, but leave the screen protector on.
    Then you put everything back and when you make sure it works, then you remove the screen protector.
    Then you put all the trim pieces back.
    It’s a 15 to 20 minute job, I recommend you wear gloves so you don’t scratch or foul the new lens you just installed.
    CSVT likes this.
  12. Jun 24, 2024 at 6:05 PM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    OP, Listen to this guy
    Screen Protech...works Perfectly....it hid all my scratches...You get 2 sets just in case you mess up 1st attempt..
    Use a water bottle with a few drops of dishwashing liquid. Spray the dash 1st the the backside of the Screen Protech..line it up then use a credit card or flat service to remove air bubbles.
    I promise when it dries you'll not see a scratch that's visible.
    The Screen Protech doesn't scratch .atleast mine doesnt
    CrashZone and Hogleg918 like this.
