Cleghorn night run- stock trucks welcome
Discussion in 'Southern California' started by Spencer, Sep 10, 2015.
  1. Sep 10, 2015 at 6:27 AM
    Spencer
    Spencer [OP] Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Title says it. Cleghorn trail run, starting at 730 meet off Cleghorn road off the 15. Should only take 2 hours or so. Trail drops off at the 138, plan is to take that down to the 15 and end the night at Toby Keith bar in Rancho. Bar may change if anyone knows a better one in the area.
    We'll go slow if you need and 2wd trucks welcome. Come out and put that light bar to use! I'll cover the rest.
    f2528ed802a2a6dfe699abd796063bd5_35a8762f86102b534a50a6224d607c7fe0e201fe.jpg9d371931bd665628b40f1ab396e59a1c_225c9408fb61df8c47e12afe51c2956aa2f5b99e.jpg
  2. Sep 10, 2015 at 12:45 PM
    jluu44
    jluu44 Well-Known Member
    Jon
    North County San Diego, CA
    2016 Tacoma DCSB 4x4 off-road
    When is the run?
  3. Sep 10, 2015 at 3:11 PM
    Spencer
    TIGGLEBITTIES
    Haha shit all this and I didn't even put a date down!
    This Friday night September 11
    ALSO
    Slight change of plans.
    To avoid the traffic if there is any that late, we will be meeting up off of Sierra (most likely at the shell station with the McDonald's ) and will be heading up lytle creek to use the cutoff that drops you onto the 138 west of the 15. Pretty cool cutoff, and once you learn it I've used it to get around the pass when it's closed or traffic is destroyed. Once back on the 138 we'll head east, cross the pass and run Cleghorn trail backwards, dropping you off onto the 15 again.
    A little longer loop, but it'll be well worth it should traffic be bad.
  4. Sep 10, 2015 at 3:13 PM
    Spencer
    TIGGLEBITTIES
    Side note, I say 730 because that usually means we'll all be there by 8 or so. There's only a couple of us going so far so lemme know if the time doesn't work for ya.
