"Click" sound from clutch when depressing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cornwall325, Apr 18, 2010.
  1. Apr 18, 2010 at 2:57 PM
    cornwall325
    cornwall325 [OP] Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    The truck of subject is a 2009 DC TRD Sport with the 6-speed tranny. I have noticed lately that I get a "click" sound when I depress the clutch. For instance if I'm taking off and going through the gears I get a single click sound every time the clutch is depressed and I change a gear. I looked underneath at the rod that's got the nut attached and it actually has a little big of wiggle to it so I'm assuming that's where the noise is coming from. Truck only has 6K miles on it. Are there any others out there who's 6-speeds do the same thing or am I going crazy? Just wondering if this is something I don't need to worry with or if it's something I need to get checked out.
  2. Apr 18, 2010 at 3:22 PM
    jimmydean
    jimmydean Well-Known Member
    Camarillo, CA
    16' DCSB TRD SPORT 6M
    Limited Grill/Wheels, 265/65/18 Nitto RG
    I'm pretty sure thats the cruise control kill switch that you're hearing
  3. Apr 18, 2010 at 3:26 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    It is probably the Cruise Control switch. Mine does that occasionaly especially when I am getting on and off the Autobahn (freeway). If you are worried about it I sure would not be afraid to take it in, warranties are awesome.
  4. Mar 23, 2013 at 4:37 AM
    ChrisGralnic
    ChrisGralnic Well-Known Member
    Southern cali
    06 Prunner with AAL and Trd suspension W/lift
    Previous owner used to haul heavy loads, so he put an AAL on it and TRD front suspension with a lift and custom rear suspension for added weight capacity. I recently installed a tow package (Curt with lifetime warranty) So i will definitely see what this thing can handle as far as weight goes.
    Not the kill switch. I am experiencing the exact same thing and mine is a base with no cruise.
