clicking and vibrations when slowing down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2gtacoma, Sep 22, 2010.
  1. Sep 22, 2010 at 4:18 PM
    2gtacoma
    2gtacoma [OP] Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    I am trying to isolate this problem my 05 access cab v6 6speed is having bad vibrations when decelerating once i let off the gas when i get under 30mph it gets bad untill i stop and it also has a clicking sound and i can feel vibrations through the shifter only. the vibrations make the inside cab creak they are starting to get that bad. this just started last thursday
    Im thinking possible u joint issues.
    Possible trans issue.
    anyone out there have any similar issues. btw the truck has 159k on it and this is the first problem i have had in my 2 years of ownership.
  2. Sep 22, 2010 at 4:23 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I'm not sure what it is, but I would suggest changing the transmission oil and see what happens. But it kinda sounds like it is internal, something wrong inside the trans.
  3. Sep 22, 2010 at 4:26 PM
    2gtacoma
    Daniel
    H-town
    05 -PreRunner sr5
    im dropping fluids tomorrow when i get home i would tonight but i have a night class.
  4. Sep 22, 2010 at 4:35 PM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    I had one side of a u-joint go out on a old truck, I heard a fate clicking when letting off the gas. The u-joint looked good on the outside, I got it apart and sure enough one of the ends was completely dry. The clicking was the needle bearings moving with no grease. Try tapping the u joint ends lightly with a hammer to see if they move any or rusty dust comes out, or just grab the drive shaft and move it.
  5. Sep 22, 2010 at 4:40 PM
    2gtacoma
    Daniel
    H-town
    05 -PreRunner sr5
    thanks, I have only visually inspected them they are not missing their caps so im going to have to pull one off and see if its bad i think like $15 or $20 at oreilly's
  6. Sep 22, 2010 at 8:43 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Post pictures of u-joints .. usually its easy to see if they are bad or not...
  7. Sep 22, 2010 at 9:40 PM
    2gtacoma
    Daniel
    H-town
    05 -PreRunner sr5
    ill have pictures and and an update tomorrow i already bought the u joint tonight and will change it out tomorrow once i get home from work. should'nt take that long.
  8. Sep 22, 2010 at 11:37 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Before you start just throwing parts at it, get it diagnosed first. I lost a weight on my drive shaft on my Dodge Ram, did'nt realize it until I changed just about every rotating part.
  9. Sep 22, 2010 at 11:41 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    2x
    Sounds like what my first gen did. I didn't have the clicking though. Vibrations are a pain to diagnose, lots of possible causes.
  10. Sep 23, 2010 at 7:02 PM
    2gtacoma
    Daniel
    H-town
    05 -PreRunner sr5
    ok so i just got done and the vibrations are gone for now and no more clicking but i had one question the black cover that goes over the out put shaft does it have a gasket or something
  11. Sep 23, 2010 at 7:17 PM
    2gtacoma
    Daniel
    H-town
    05 -PreRunner sr5
    The arrow shows the cover im speaking of
  12. Sep 23, 2010 at 10:19 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    There will be a rear seal to the transmission in there if thats what your asking.
  13. Sep 23, 2010 at 10:33 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    If I remember correctly, that black shield should be connected to the front yoke...
  14. Sep 23, 2010 at 10:37 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Nevermind, It IS supposed to be on the front yoke.
