clicking noise at speeds above 35mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rleip21, Dec 6, 2014.
  1. Dec 6, 2014 at 6:25 PM
    rleip21
    rleip21 [OP] Member
    I have a 2010 tacoma 4x4 trd off road manual v6. For a while now I have had this clicking noise that would sound exactly like a stone is in my tire. I usually here it with window down at about 35mph and above. Obviously no stone or screw in tire. Seems like it is coming from drivers side. If I put in neutral still makes noise so not engine. Anyone have a clue.
    Thanks
  2. Dec 6, 2014 at 9:59 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    When was the last time you greased the u-joints?
  3. Dec 7, 2014 at 4:36 PM
    rleip21
    rleip21 [OP] Member
    Never greased the u joints. Do they have a grease fitting on them.
  4. Dec 7, 2014 at 7:08 PM
    M R duckcall
    M R duckcall Member
    South Carolina
    Trd sport
    Procomp 3 in suspension lift 33 in tires and 17 in Moto metal rims
    I have the same issue in mine. Grease u joints at every PM I think it may be where the lower bumper is riveted to the aluminum crash bar
  5. Dec 7, 2014 at 9:42 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    On the offroads, you should be able to se a grease zerk sticking out of the u-joint cap on the rear shaft, on the front the zerks are in inside of the u-joint,"or center of the cross" just stick your finger in there and you'll feel it.
    If your lucky greasing the joint might stop the clicking, if it doesn't then it's time to find which joint is bad and replace it.
    With 4yrs of never being greased you might have to replace all 3 in the rear shaft.
  6. Dec 8, 2014 at 9:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If Greasing it effects the sound it is a good troubleshooting step, but if it is clicking it is too late already. The only good way is to remove the drive shaft to verify the U-Joints are sound or not. If you have one worn out I would replace all the joints at the same time.
  7. Dec 9, 2014 at 4:45 AM
    Pavlovsdog
    Pavlovsdog Active Member
    Tampa, FL
    07 PreRunner 2WD
    Probably Ujoints, but with that being said I had a weird one that was similar. A slight rhythmic click from the drivers side wheel. I took the tire off, and somehow the retaining clip came off the brake pads. I put a new one in and the brake rattle went away...
  8. Dec 10, 2014 at 3:08 PM
    rleip21
    rleip21 [OP] Member
    I will go ahead and grease the u joints and see what happens. My truck is a trd off road. The only thing is it only has 10000 miles on it so seems kind of weird that u joint would be bad even if I did not grease them. I guess I will find out when I grease and take a ride to see if noise changes. Thanks for all your help. If that doesn't work I will look for the clip. On that are you talking about the squeeler clip when pads run low. Or something else.
  9. Dec 10, 2014 at 4:50 PM
    Pigpen
    Dan
    Northwest Montana
    There's a retainer clip on the brakes which will be obvious when you look at them.
  10. Dec 13, 2014 at 5:57 PM
    rleip21
    rleip21 [OP] Member
    Well greased the u joints all 5. Back 3 took a couple pumps of grease. So probably were a little dry. Front would not take any. Drove my truck. No change in noise. Checked retaining clip in brakes was fine. Forgot to check front bumper rivets. Found one mud flap clip broke. Does wobble not sure if that would cause the noise. Going to order some. Any other suggestions besides close my window? Thanks
  11. Dec 13, 2014 at 6:09 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    This is what the stealership would say.
    Anyway is the click only when turning? Or it does not matter?
  12. Dec 15, 2014 at 4:12 PM
    rleip21
    rleip21 [OP] Member
    It does it all the time when above 35 but is worse when turn to right. I saw videos of cv joint bad and was more of a lower pitch sound. So don't think it is that. I also saw front bumper aluminum brackets but tried shaking them no movement. So puzzled. Figure if I take it to the stealership they won't figure it out or they will just start replacing stuff and cost me a fortune.
  13. Dec 15, 2014 at 4:46 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Silly, but i wonder if you have a cracked rim or something wrong with the lug bolts.
    If you or have you rotated the tires to see if it's still sounds?
  14. Dec 15, 2014 at 8:02 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
  15. Dec 17, 2014 at 5:34 PM
    rleip21
    rleip21 [OP] Member
    I basically pumped them up till it was hard to pump. Did not have grease leaking out. I will try and rotate tires.
  16. Dec 17, 2014 at 6:03 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Hopefully, when you rotate the noise will come from another wheel area well not hopefully. ......you know what i mean. Lol.
  17. Dec 17, 2014 at 8:25 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    You need to keep pumping, it will get hard to pump cause of the old dried grease in there, pump some more and you should hear a little pop and grease should come out of the u-joint caps, probaly just one cap at first. In a couple of days grease them again till you can get grease from all 4 caps at the same time.
    Idea being to push the old grease out of the joint with new grease, if that doesn't work then it's too late, the joint is probaly bad which would cause your clicking noise.
  18. Dec 17, 2014 at 8:57 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    X2
  19. Dec 27, 2014 at 9:56 AM
    rleip21
    rleip21 [OP] Member
    Okay so greased the u joints properly and no change in noise at all. I checked the old grease for metal but saw none. So I drove again and tested. I found that the clicking goes away when turning left. The clicking gets worse when turn to the right. I have tried to shake everything to see if it was just a piece of plastic and the only loose part is the mud flap which I ordered a new clip for. So any new suggestions. I could be wrong but I don't think it's ujoint if sound goes away when turning left. Thanks again for your help.
  20. Dec 27, 2014 at 10:00 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Cracked rim or hub? Maybe some the lug bolts are broken? Idk just suggestions. Did you rotate and see if the noise moves.
