Clicking noise coming from tranny each time my turn signal clicks when in park
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cooperm77, Jul 20, 2022.
  1. Jul 20, 2022 at 11:55 AM
    Cooperm77
    Cooperm77 [OP] Member
    Cooper
    Toyota Tacoma 2002
    4x4 3.4L E-Locker
    Hey guys,
    I recently purchased a 2003 double cab with a 3.4 and auto trans
    I noticed well driving home that my cruise control stops working each time I turn either one of my turn signals on, I also notice a slight down shift (jump around 250 rpms) when I turn my turn signal on. Then today I was trying to figure it out and put my turn signal on while my truck was in park and noticed a clicking noise coming from the tranny each time my blinker clicks. Any help would be much appreciated!
  2. Jul 20, 2022 at 1:23 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Sounds like an electrical ground issue. Start at the turn signal bulbs themselves and work your way back. With a new to you truck, you might find some "custom" wiring from the previous owner.
    jbrandt and MalinoisDad like this.
  3. Jul 20, 2022 at 1:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Do you have an aftermarket alarm and do you have trailer wiring.
    Wulf likes this.
  4. Jul 21, 2022 at 7:16 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your hearing must be fantastic to hear a shift solenoid in the transmission.
    It does sound like a ground feeding back through another circuit. The turn signals the transmission and cruise control do share some ground locations.
    Charging system working like it should?
    Physical damage to the harness or some left over custom wiring
    Good luck wiring gremlins can be difficult.
  5. Jul 21, 2022 at 10:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like something is backfeeding the brake circuit either due to a short or bad ground, what your hearing is likely the shift interlock solenoid clicking.
    I'd start with checking the rear bulbs, related grounds, and trailer converter harness if you have it.
    If someone put LED bulbs in the rear that can cause this problem as well.
    Bivouac likes this.
  6. Jul 21, 2022 at 11:23 AM
    Cattywampus
    Cattywampus Splitter of CV Boots
    Mark
    Colorado
    '03 Tacoma DC TRD OR
    ^^^ what he said.
    Had this issue. Check your trailer harness, the turn signal can backfeed the brake light circuit if the harness is the wrong one, shorted, or wired incorrectly. The auto transmission uses the brake light circuit to signal unlocking the torque converter, so if stray current is ending up in the circuit, you have the issue you're describing. Turn on your turn signal and see if your brake lights are flashing in sync, it will prob be faint so look closely.
    TACOTU3 and Speedytech7[QUOTED] like this.
