CLICKING NOISE FROM DRIVERS SIDE
Discussion in 'Suspension' started by bdonham1993, Dec 3, 2012.
  1. Dec 3, 2012 at 7:05 AM
    bdonham1993
    bdonham1993 [OP] New Member
    Brendon
    Tucson
    09 PreRunner
    3 inch revtech lift with add a leaf in the back magnaflow that drops down before rear axle knn 63 cold air intake
    ok so after a ruff day of offroading i was coming out of the trail i notice a clicking noise everytime i turned or would roll over a bump after doing some research i came to the conclusion it was my lower ball joint so this weekend me and a buddy took off my control arm went to base punched out the old ball joint and punched in a new one then put it all back together and there is still a click im running out of ideas i have heard people say that it could be the tie rod but i dont know just want to get some ideas on how else i should go about this
  2. Dec 3, 2012 at 7:25 AM
    52motorhead
    52motorhead Well-Known Member
    Clicking sound while turning sounds more like a cv joint in the front axl.
  3. Dec 3, 2012 at 1:25 PM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    is it a steady click click click while you are moveing if is this probably a cv !!!!!!! prerunner whoops !!!!!
  4. Dec 3, 2012 at 1:27 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Beaverton, OR
    SWB 05 Double Cab 4x4 TRD Off Road
    Is it possible to get a video of it as well?
  5. Dec 3, 2012 at 1:32 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Could also be a wheel bearing
  6. Dec 3, 2012 at 1:34 PM
    MonkeyProof
    SoCal- SGV
    Says in his details that he is a prerunner
  7. Dec 3, 2012 at 1:49 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Blinker still on?
  8. Dec 3, 2012 at 1:53 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    bushings.
    click noise when going over bump, or turning, LCA bushings for sure.
  9. Dec 4, 2012 at 6:58 AM
    bdonham1993
    Brendon
    Tucson
    09 PreRunner
    i have also heard that it could be the cv as well.... i will try to get a video today after work and post it so yall can hear it thanx for all the response on this issue
  10. Dec 21, 2012 at 7:51 AM
    kyser13
    kyser13 Well-Known Member
    09 Tacoma/SR5 4X4
    Debadged, Inno bed rack blacked out brackets, Blacked out front Toyota badge, Interior red LEDS, 285/17-70 Duratracs, 17X9 Moto Metal 957s, Toytec 3" lift Bilstiens, Ultra Gauge, LED bed lights.
    i have a little bit of a click or pop every now and then in the driver and occasionally in the passenger. not all the time just occasionally for both. Any ideas on that, this is after a Toytech lift has been installed since mid October and the popping just started. Mostly noticed it is when turning or a slight bump.....any help would be great.
  11. Dec 21, 2012 at 7:54 AM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    sounds more like a wheel bearing.
