Clicking noise from front passenger tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsnm23, Dec 8, 2020.
  1. Dec 8, 2020 at 7:50 AM
    jsnm23
    jsnm23 [OP] There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    I have a clicking noise coming from the front passenger tire that speeds and slows with tire rotation but goes away when I apply brakes.
    I recently replaced the brake pads.
    Any ideas?
  2. Dec 8, 2020 at 7:53 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Check the tread. It could be as simple as a rock wedged in the grooves or a screw, nail, staple.......
    If not something wedged or stuck in the tire, then probably need to go back to check your brake work.
  3. Dec 8, 2020 at 7:58 AM
    jsnm23
    2011 mgm TRD OR 4x4
    I'm hoping its my brake work. I don't think its something in the tire as the noise goes away when I apply the brakes.
    I'm just hoping its not a wheel bearing.
  4. Dec 8, 2020 at 8:03 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I would check the brake anti rattle clips, honestly I don't recall if 2nd gen tacoma has them or not.
  5. Dec 8, 2020 at 8:07 AM
    Soulstice07
    Soulstice07 Well-Known Member
    Granite Falls, WA
    2010 TRD Off Road
    6" Pro Comp lift KMC 17x9 XD137 FMJ Wheels 35" Mastercraft tires Custom Bilstein extended length adjustable coilovers 700lb Eibach springs Bilstein rear shocks DV8 Off Road front bumper Custom skid plates/armor Smittybilt 10klb winch Cali Raised LED sliders Cowl air induction ABS kill switch Rear air ride suspension Trailer plug relocate Clazzio leather seat covers Various lighting mods
    Wheel bearings dont click, they groan, and eventually start making a grinding/scraping noise if not replaced. Definitely sounds like brake work
  6. Dec 8, 2020 at 8:08 AM
    Soulstice07
    Granite Falls, WA
    2010 TRD Off Road
    2nd gens DO have the clips, thats most likely what it is
  7. Dec 8, 2020 at 8:14 AM
    jsnm23
    2011 mgm TRD OR 4x4
    Would the clicking from the brakes speed up as tire rotation speeds and decrease as rotation slows?
  8. Dec 8, 2020 at 9:03 AM
    joeyv141
    New Jersey
    If the noise is related to the brake job then yes.
  9. Dec 8, 2020 at 9:06 AM
    sabasarge
    sabasarge Well-Known Member
    central Columbia Gorge
    2020 Sport AC MT cement
    Working on that
    Hate to sound simplistic, but a rock stuck in the tread will mimic that sound.
    Clearwater Bill and BillsSR5 like this.
  10. Dec 8, 2020 at 12:21 PM
    Soulstice07
    Granite Falls, WA
    2010 TRD Off Road
    If it was a rock in the tread it would not go away when braking
    jsnm23[OP] and joeyv141 like this.
  11. Jun 15, 2022 at 10:46 AM
    Azxethy
    Azxethy New Member
    Daniel
    2014 Red Baja DCSB
    Dealing with the same thing myself. Did you end up resolving this issue? I'm hearing a clicking from the front driver side wheel, with every rotation of the wheel. Loud until I get above about 30 mph - mainly hear it in my neighborhood with the echo bouncing off houses. Noticed the clicking will stop when I apply the brakes.
    Took it to a local shop and had the guys check it out - they thought it was a messed up axle, but that wasn't the case. They said my pins were sliding out of my pads on my passenger side wheel. They just noticed a bunch of brake dust on the driver side - they cleaned that stuff out. Noise went away for a day and its back.
  12. Jun 19, 2022 at 4:30 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    Any update on your end with this issue? Having the same issue, jacked up my tire and rotated didn’t make a noise. I also took the center cap off and no luck.
  13. Jun 19, 2022 at 8:09 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I did a couple of threads about this. It's probably either the spring on the brake pads, try replacing it or adding a second one, or if you just did brake work you probably forgot to put a thin coat of brake grease on the back of the pads so that they stick to the caliper.
    9TRDTCO likes this.
  14. Jun 21, 2022 at 10:25 AM
    Azxethy
    Azxethy New Member
    Daniel
    2014 Red Baja DCSB
    Ended up taking my truck back into the same shop and recommended that they apply an extra pad clip, as recommended by this thread: https://www.tacomaworld.com/threads/tick-tick-click-click-from-front-brakes.582633/
    That was on Friday, 6/17. Drove it all weekend and so far, so good. No clicking noise whatsoever. Shoutout to that guy above in the thread link^
    9TRDTCO[QUOTED] likes this.
  15. Jun 23, 2022 at 12:39 AM
    9TRDTCO
    I actually already have two clips. But I will have to check this out as the sound does sound about the same. Thank you!
