Clicking noise going over speed bumps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigChungah69, Oct 13, 2022.
  1. Oct 13, 2022 at 4:18 PM
    BigChungah69
    BigChungah69 [OP] Member
    Harrison
    2019 Toyota Tacoma SR5
    Hello everyone, it’s my first post! I have a 2019 Toyota Tacoma SR5 that has had a slight clicking sound on the front drivers side whenever I go over a speed bump around 35-40kmph it made the same noise when I first got it and it hasn’t gotten any worse or better but now it’s really starting to bother me. Could anyone suggest anything that it could be ?
  2. Oct 13, 2022 at 4:51 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Is there a loose penny in your cup holder?
  3. Oct 13, 2022 at 6:22 PM
    kshoots
    kshoots Active Member
    HI
    2017 Quicksand TRD Sport 4x4 DCSB
    I have chased this sound for a while, it comes and goes. I replaced the worn support bushings in the front with poly, kind of toned down the noise as worn factory bushings were metal on metal. Then replaced front suspension with eibach and noise went away for a good 6months. Now its coming back again. I just hit the gnarly bumps a little slower and its quiet. Theres a speedbump that fronts my work that everyone hauls over and you can hear every Tacoma 2nd or 3rd gen "click" as they go over it. I heave read Toyota techs claim its the shocks but these are stock, lightly modded, and mental 12" lifts all making the same noise.
    There are a few threads already made here on the subject, sorry i dont have the links.
    Good luck!
    BigChungah69[OP] likes this.
  4. Oct 13, 2022 at 6:30 PM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Could be something loose or broken like a sway bar link. I will tell you to start simple though, because I thought I had a clunk going over bumps, when in reality, it was just my hitch rattling in the receiver :rofl:. I would check to make sure everything is torqued, and nothing is loose to start off. Noisy shock internals are also a possibility, and wouldn’t surprise me honeslty.
  5. Oct 13, 2022 at 6:33 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Likely core support bushings. If you are within warranty, take it in
  6. Oct 13, 2022 at 7:47 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Ive Been chasing that for a year now.. good luck. Different things wrong on different truck all make that sound close to the same..
  7. Oct 14, 2022 at 4:26 PM
    BigChungah69
    Harrison
    Wow thank you all so much for the helpful info! I’m really happy I joined this forum.. you guys rock!
  8. Oct 14, 2022 at 4:31 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Another possible cause is loose spare tire. But sounds like its coming from the front.
  9. Oct 20, 2022 at 12:23 PM
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    You aren't supposed to go over a speed bump at 40 mph
    Chew, Mark77, TXpro4X4 and 1 other person like this.
  10. Oct 20, 2022 at 12:33 PM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    Pffft.... its more fun that way
    Kolohe07[QUOTED] likes this.
  11. Oct 20, 2022 at 12:40 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Still under warranty?????
  12. Oct 20, 2022 at 12:57 PM
    JonWB
    JonWB Well-Known Member
    Jon
    Idaho
    2018 TRD OR Access Cab
    It’s wildly frustrating. I took mine into the dealer multiple times, but the “techs” were useless. I even drove with a dude and demonstrated it to him. A lot of threads seem to think it’s the body mount bushing, but supposedly mine are normal.
  13. Oct 20, 2022 at 12:59 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Mine does this up front, there is a speedbump near my house and every tacoma that goes over it makes the same clunk. I think it's a bad strut or bushing on a control arm but I can't find shit.
  14. Oct 20, 2022 at 1:02 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    +1 for swaybar link as well, but I will tell you I chased a similar sound for a week before someone on this board recommended checking the sunglass holder and, sure enough, there was my issue...noisy sunglasses. So, check that!
  15. Oct 22, 2022 at 5:21 PM
    BigChungah69
    Harrison
    Sadly no!!
    Tocamo[QUOTED] likes this.
  16. Oct 22, 2022 at 5:22 PM
    BigChungah69
    Harrison
    Thanks for your input I appreciate it! No sunglasses in the holder and the sound is definitely coming from the front suspension area
  17. Oct 22, 2022 at 5:24 PM
    BigChungah69
    Harrison
    It’s so frustrating.. when I had my stock 98 xj cherokee I used to jump speed bumps with no clicks or clunks
  18. Oct 22, 2022 at 5:26 PM
    BigChungah69
    Harrison
    Now that is super frustrating, I wish I could figure this out. If and when I do I will post for all to see
  19. Oct 22, 2022 at 5:29 PM
    BigChungah69
    Harrison
    Thank you for your advice Much appreciated
  20. Oct 22, 2022 at 5:30 PM
    BigChungah69
    Harrison
    Thank you so much for your input it’s nice to know that so many others are dealing with a similar noise!!
