Clicking noise going over speed bumps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigChungah69, Oct 13, 2022.
  1. Oct 22, 2022 at 5:39 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I'll go with swaybar.
    Noise is coming from the front
    If possible for you take an hour remove your swaybar. Drive for a while and see if the noise goes away. What you got to lose?
    Good luck
    BigChungah69[OP] likes this.
  2. Oct 22, 2022 at 5:42 PM
    BigChungah69
    BigChungah69 [OP] Member
    Harrison
    2019 Toyota Tacoma SR5
    Hey thanks a lot man that’s a great idea to try and tick possible reasons off the list! I appreciate your input greatly
    TXpro4X4[QUOTED] likes this.
  3. Oct 22, 2022 at 5:44 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I had a noice I chased for years. Turned out to be my bed rattling. A cheap spacer fixed it. Search bed rattle spacer fix and you’ll see what I’m referring to.
  4. Oct 22, 2022 at 6:21 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    My truck use to make a clink when I hit pot holes on a road trip I went on. pretty sure it was that little metal spiral tube on the passenger side engine bay hitting the wheel well. I think a piece of foam may have came off
    had my wife sit in the truck while I tapped it against the well and she said it sounded just like it
  5. Oct 22, 2022 at 6:46 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    40kmph is 25 mph.
    Kolohe07[QUOTED] likes this.
  6. Oct 22, 2022 at 6:55 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I'm almost positive mine is a bad shock. It only makes the noise when it is bigger hit, IE one that would fully compress the shock.
    TXpro4X4 likes this.
  7. Oct 24, 2022 at 1:39 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i get a squeaking/chirping noise from the rear when going over speed bumps. i think it's the leaf bushings.
  8. Oct 27, 2022 at 9:18 AM
    get_nick
    get_nick Well-Known Member
    Seattle, WA
    2017 Blazing Blue Limited
    Do you know the part number for these? I might need to give this a shot. My dealerships have exhausted all other options.
  9. Oct 27, 2022 at 3:43 PM
    SteveB313
    SteveB313 Well-Known Member
    Detroit
    20 Tacoma TRD OR blackout/MGM, dbl-cab, AT3W’s
    Do you have a trailer hitch? Felt like an idiot when I figured it out after months of head scratching.
  10. Oct 27, 2022 at 3:47 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    you can actually mount a tow ball to the bumper itself.
  11. Oct 27, 2022 at 3:57 PM
    SteveB313
    Detroit
    True, with 3500 capacity, I’ve got the tow package and use a multi hitch with capacity up to 6800. Tbh, keeping the hitch attached has spared my bumper from more than a few dings.
  12. Oct 27, 2022 at 6:45 PM
    Hooper89
    There's a speed bump thing literally in front of my house and every tacoma that hits it makes the clunk lol.
  13. Oct 27, 2022 at 6:51 PM
    wb_doublecab
    wb_doublecab Well-Known Member
    2020 ORLB
    My 3rd gen does this in the rear. My 2nd gen did the same thing. The rear leafs suck and mine are hitting bumpstops.
  14. Oct 27, 2022 at 7:14 PM
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    Mine did this and I replaced the front bushings with poly, still made the noise. So I replaced the lower ball joints. No more noise. Maybe just coincidence? I wanted Moog serviceable ball joints and it was a PITA to do but happy I can grease them up now.
  15. Oct 27, 2022 at 7:30 PM
    #35
    JK
    JK Well-Known Member
    Northern California
    2018 Super White Tacoma TRD Off Road
    I get a similar sound. I think it’s my stock trd off-road front skid plate though
  16. Oct 28, 2022 at 1:54 AM
    #36
    JonWB
    JonWB Well-Known Member
    Jon
    Idaho
    2018 TRD OR Access Cab
    For what it’s worth, when I drove with a dealer technician and demonstrated the sound to him, his only guess was that a skid plate might be loose or have a rock stuck in a joint. He took a look and made sure everything was tight, but wasn’t able to determine the cause.
    The next time I took the truck in, I asked them specifically to check the front body bushings. They said they did, and that they were fine. I left the dealership and didn’t hear the sound for a few months. It’s possible it was a coincidence, but I’m pretty good at predicting what type of bump will elicit the clank at this point. I think they either tightened something or did something else that fixed the issue temporarily.
    I refuse to let the dealer touch my car at this long so I haven’t pursued it further. I’ll be having a shop upgrade the suspension soon and I’m hopeful we’ll be able to determine the cause in that process.
    JK[QUOTED] likes this.
  17. Oct 28, 2022 at 12:17 PM
    #37
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Any luck yet?
  18. Oct 28, 2022 at 12:24 PM
    #38
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    When my 2019 was new it started making a clicking noise, seemed to be coming from the front driver side. Turned out to be a loose skid plate rattling
  19. Nov 27, 2022 at 10:11 PM
    #39
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    My 2013 has a suspension "click" when going over a speed bumps or just larger suspension compression situations. Taking swaybar off made no difference. I've had my LCA bushings replaced, front springs replaced, skid plate checked, click is still there... for the past almost 9 years now!
  20. Nov 29, 2022 at 8:44 PM
    #40
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Im giving up looking for it now the winter has hit.
    Had the skid plate off for 2 months and still could not find it, need to look at my go-pro video that i took under the trucker better at a latter date some time.
    I did find cracked sheet metal under the battery box that i fixed, but that was a clicking not a clunk....
