Clicking Noise When Thermostat is Turned to HOT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shebisen14, Dec 4, 2018.
  1. Dec 4, 2018 at 6:57 AM
    Shebisen14
    Shebisen14 [OP] New Member
    Started hearing a fairly significant "clicking" noise behind the dash when I turn the temperature to the hottest setting. Any ideas what would cause this? Sounds like a relay. Appreciate any suggestions.
  2. Dec 4, 2018 at 2:32 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Your problem is the gear in the servo for the blend ( Air Mix Servo ) door temperature control. Cheap and easy to replace.
    Lester Lugnut likes this.
  3. Jan 5, 2019 at 10:48 AM
    Shebisen14
    Thanks Jimmyh! Do you happen to know the part # on this? I'm having problems locating it. The original has 52402808/030073021A on it. However, Autozone and O'Reilly's can not cross the number or find a replacement. They are telling me I need to get it from the dealer. Don't want to go that route obviously. Any help would be appreciated!
  4. Jan 5, 2019 at 11:07 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  5. Jan 6, 2019 at 11:50 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Good post Chuy!
    From his linked post:
    ACDELCO Part#1573513 (1572858, 15842338, 52494371)
    DORMAN Part#604109 (autozone and o'reilly carry this one)
    STANDARD MOTOR PRODUCTS Part#F04007
    Chuy likes this.
  6. Jan 7, 2019 at 12:01 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Servo, Mode Control Servo 87106-04050
    Your number crosses to this Part # Servo, Air Mix 87106-04060
  7. Jan 7, 2019 at 6:16 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Make sure the door is not jammed and can swing freely before you install the new servo
  8. Jan 7, 2019 at 8:43 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Mine started doing this not too long after it went out of warranty. This will no doubt help out. Thanks.
