clicking noise when turnin and braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlalien, Sep 10, 2011.
  1. Sep 10, 2011 at 9:51 PM
    dlalien
    dlalien [OP] Well-Known Member
    Jose
    North Hollywood CA
    08 TRD Sport DCLB 4WD, Tow package
    I just niticed that when i turn the wheel in a complete lock there is a loud clicking noise and when im in reverse and push on the brake there is also a lound cliking noise the same when in in drive and push on the brake. I notice it more when i an parking. Any toughts on what this might be?:confused:
  2. Sep 10, 2011 at 9:53 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    If it is just when at full lock, it is probably the steering stops. When I took mine into the dealer about this they just greased the stops and it hasn't made a noise since.
    PS: had this done 23000 mile ago. and still no noise from it.
  3. Sep 10, 2011 at 9:59 PM
    dlalien
    Jose
    North Hollywood CA
    I tought of that but the noise happens befor it comes to a full lock
  4. Sep 10, 2011 at 10:00 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Does it do it if the wheels are not turned and you hit the brakes?
  5. Sep 10, 2011 at 10:10 PM
    dlalien
    Jose
    North Hollywood CA
    No it only does it when im turning the wheels and hitting the brakes at the same time if the truck is in park and i turn the wheels it turns fine
  6. Sep 10, 2011 at 10:12 PM
    S.B.
    Sean
    San Diego
    15 Taco
    It might just be the pads moving a little bit. Its normal for the pads to move slightly.
  7. Sep 10, 2011 at 10:21 PM
    dlalien
    Jose
    North Hollywood CA
    I dont know its a loud noise i havent herd it before even when im parking i revers hit the brake then click i move forward hit the brake then an even louder click i hear it even with the radio on. Tomorrow im going to take a closer look see if i can figure out where its comming from.
  8. Sep 10, 2011 at 10:26 PM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    if its clunking its probably your ball joints
  9. Sep 10, 2011 at 10:26 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    jack the truck up and rock the tire, see if it moves back and fourth, thats how you know its your ball joints.
  10. Sep 10, 2011 at 10:33 PM
    dlalien
    Jose
    North Hollywood CA
    Ill check them out too, thanks I fiqured it happens when i brake so it must be the brakes
  11. Sep 10, 2011 at 11:20 PM
    nubbs
    nubbs Only from the waist down.
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    3.5" CST Spindle, 5100 Series Bilstien Shocks, 1 1/4" Spidertrax Wheel Spacers, 295/75/16 BFG AT's, EBC Slotted and Dimpled Rotors, EBC Green Stuff Pads, K&N Drop-in, Pioneer Avic-Z110BT GPS Head Unit w/ E-Brake Mod, Ipod Integration, Integrated Pioneer XM Radio Receiver, 6 1/2" Infinity Kappa Separates, 6 1/2" Infinity Kappa Coaxles, Custom Speaker Adapters, PAC Stealth Backup Camera (Because anyone in a double cab knows you can't see the tailgate.)
    Don't know if you have figured this out yet, but it sounds like an issue that I had in the past. If it truely is a "clicking sound" as you stated, there's a good chance it might be the same. If you were to remove your front bumper skin, you would find the front bumper bar. It is a boxed alluminum tube, that is bolted to (2) alluminum mounts, that are in turn bolted to the frame horns. In my case, after an extensive process of elimination; I discovered that the "clicking" eminated from one of the alluminum mounts. These mounts are also a boxed tube, with plates welded onto the ends for flanges. Where I found the issue was the boxed tube portion, as it is not monolithic; rather it is multiple plates welded together to form the box shape. One or more of the welds had likely cracked, though not visibly; probably brought on by flexing of the frame. I confirmed my theory by removing the entire front bumper assembly and driving the truck, performing various stops and turns, etc. I was fortunate to have come across a set destined for the recycling heap and have never heard this again.
    As I have written this and reflected back, I have become even more sure that this is likely your issue, based upon your description. I remember how frustrating that had become and how I had begun to hate my truck for a time.
    Good luck, let me know how it goes.
  12. Sep 10, 2011 at 11:33 PM
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    If it is mainly while turning, full lock or not, and if it sounds like it's coming from the rear then it could be a chipped tooth on the ring gear. If that's the case you should get it looked at before more damage is done. Just one chipped tooth will cause the whole rear end to grenade (called that because when you open the rear end that's what looks like what happend) and you end up having to replace the whole rear end axels and all. If you catch it before that happens you can usually just replace the ring and pinion.
  13. Mar 20, 2012 at 4:27 PM
    Tunafish76
    Tunafish76 Member
    Eric
    NC
    05 DC SR5
    3" lift 33" BFG's K&N Cold Air Intake Camper Shell
    Right there with you guys. The click is off the bumper "frame" welds, or lack there of. The dealer was oblivious, but after insisting, there was a TSB found. I was way out of warranty though. Pull off the plastic, and Frame. Take the frame, reinforce weld, and re-install. The TSB indicates two frame blocks as a fix for 230 apiece. Whatever the case, it is in the bumper area, and is brought on by frame/bumper flex. It is not suspension, or brake pads and will resonate from the radiator/bumper area only.
    Nubbs is right on the spot.
    Good luck,
  14. Mar 20, 2012 at 11:07 PM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    I'm glad that I might have been of help.
  15. Mar 21, 2012 at 3:42 AM
    Tookie
    Tookie Well-Known Member
    Port Vincent, LA
    2009 DC TRD Sport
    CV joint?
  16. Mar 21, 2012 at 6:36 AM
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    More of a click than a clack, so I'd say no.
  17. Jan 30, 2013 at 3:14 PM
    kyser13
    kyser13 Well-Known Member
    09 Tacoma/SR5 4X4
    Debadged, Inno bed rack blacked out brackets, Blacked out front Toyota badge, Interior red LEDS, 285/17-70 Duratracs, 17X9 Moto Metal 957s, Toytec 3" lift Bilstiens, Ultra Gauge, LED bed lights.
    Nubby can you elaborate or have any pics I have the same darn issue and its been making me crazy. I'm still in warranty should the dealer be able to fix it? I have sent u a PM. Thanks.
  18. Feb 5, 2013 at 4:41 PM
    kyser13
    09 Tacoma/SR5 4X4
    Please help anyone have pics? I'm still under warranty I think nubbs here has pinpointed my issue as well.:confused:
  19. Feb 5, 2013 at 7:22 PM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I'm getting a clank/clack/click (or whatever) in my front end as well. A few weeks ago I installed ToyTec's ultimate lift coil-overs, Light Racing UCAs, new outer tie rod ends, and new lower ball joints all at the same time. The clacking initially began only in the front left. I'd hear a thunk when turning the wheel from the right to the left as the weight of the truck shifted from one side to the other. Now, after a couple weeks, the clanking is in both sides and is getting louder/worse. I initially thought the brake pads were slapping around due to slack/play as the pads are wearing down. However, it didn't start doing this until after the lift. It's only present at low speeds (i.e. when pulling into/out of my driveway or parking spaces, and when doing low-speed turns).
    I'm thinking I either messed up the CVs in my front drive shafts or the new lower ball joints (Moog) are bad. Although I doubt it, should I be looking at my front bumper mounts as noted in this thread?
  20. Feb 6, 2013 at 4:28 AM
    Tunafish76
    Tunafish76 Member
    Eric
    NC
    05 DC SR5
    Do you still have your sway bar installed? That may be the thud when parked and not moving while turning the wheel? Or its your CVs. I have the same thing going on, just a metal to metal click at moving speed in the front on/near the bumper. I am clueless to the source still. Good luck
