Clicking sound after replacing spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by tangov559, Dec 13, 2017.
  1. Dec 13, 2017 at 2:23 AM
    tangov559
    tangov559 [OP] Well-Known Member
  2. Dec 14, 2017 at 12:44 AM
    tangov559
    any idea?
  3. Dec 14, 2017 at 1:26 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. Dec 14, 2017 at 1:28 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It could be worth it to go through your work on that side and see if you find any issues. Are the wires new too?
  5. Dec 14, 2017 at 1:38 AM
    tangov559
    yes. new wires. forgot to mention that. will be checking everything again this weekend.
  6. Dec 14, 2017 at 1:49 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You got a leaky plug wire. Run the truck in the dark and lift the hood. I'll bet you see the arcing wire pretty easy.
    wilcam47, cruiserguy and Dalandser like this.
  7. Dec 14, 2017 at 1:52 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That was what I was thinking too. Reseating it might do the trick - check the boots for visible damage. You can swap wires around if you can't see any evidence of which one it is and see if you can identify the bad one by the moving sound.
  8. Dec 14, 2017 at 2:21 AM
    tangov559
    so the new spark plug wires are bad?
  9. Dec 14, 2017 at 2:26 AM
    koditten
    Kirk
    Central Michigan
    Not necessarily, you could just have a boot that needs reseated. Or, yes, the wires could be bad. Or, it might be something entirely else, Did you look at the engine in the dark yet?
  10. Dec 14, 2017 at 2:38 AM
    tangov559
    sorry, can you elaborate on arching wire?
  11. Dec 14, 2017 at 2:39 AM
    koditten
    Kirk
    Central Michigan
    It looks like sparking, like a spark plug does, but often bigger and much louder.
  12. Dec 14, 2017 at 2:41 AM
    tangov559
    oh okay. i just checked. no sparks visible when i opened the hood while engine on.
  13. Dec 25, 2017 at 10:26 AM
    Terror
    Terror New Member
    2004 tacoma
    did you torque the plugs? I had a similar issue and found that I did not t torque one of the plugs after to rque the tick went away
    wilcam47 likes this.
  14. Dec 25, 2017 at 11:45 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I have a ticking after changing my plugs and wires as well. I get it mainly while accelerating hard in 4th gear when the engine is warm. I torqued my plugs with a torque wrench, but I'm considering taking them out to inspect my work. Engine sounded perfect prior to changing the plugs and wires.
  15. Dec 25, 2017 at 9:22 PM
    tangov559
    thanks. will have to recheck again.
