Clicking sound after safety recall.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fairhope, Aug 19, 2017.
  1. Aug 19, 2017 at 5:19 AM
    Fairhope
    Fairhope [OP] New Member
    2016 Tacoma SR-5 ex-cab.
    2016 Tacoma makes a clicking sound after satey recall. Sounds like a U-joint.
  2. Aug 19, 2017 at 6:24 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Welcome to TW OP.
    Explain clicking sound. Coming from where?
  3. Aug 19, 2017 at 6:26 AM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Also which recall?
  4. Aug 19, 2017 at 6:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    Love an info filled post. :thumbsup:
  5. Aug 19, 2017 at 6:28 AM
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Try again with more details if you need some help from the community.
    GPsevinSixx and Pittrider like this.
  6. Aug 19, 2017 at 6:30 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    He did say 2016.
  7. Aug 19, 2017 at 6:32 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Sounds like rock stuck in tread, but IDK.
    taczilla[QUOTED] likes this.
  8. Aug 19, 2017 at 7:12 AM
    Fairhope
    Recalls were, differential leak, and timing sensor bolt. Clicks too fast to be a rock in tread, but can't hear it if truck is not moving.
    rtzx9r likes this.
  9. Aug 19, 2017 at 7:13 AM
    Fairhope
    Sorry about the lack of info. I'm new at this.
    rtzx9r and harrycary like this.
  10. Aug 19, 2017 at 7:14 AM
    harrycary
    Harry
    Can you hear it at all speeds? Does anything seem to provoke it or quiet it down? Does the click go away when going around a right hand turning circle? Left hend circle? If you can hear it in the cab, can you record the sound?
  11. Aug 19, 2017 at 7:15 AM
    harrycary
    Harry
    No problem. We can help.
  12. Aug 19, 2017 at 7:28 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    No probs. Welcome!
  13. Aug 19, 2017 at 7:31 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Record the sound and post it up. Too difficult to judge without hearing it. Is it loud or muted sound? Does it seem to be coming from a certain spot?
  14. Aug 19, 2017 at 7:52 AM
    Fairhope
    Where is the 2016 Tacoma v6 2016 crankshaft position sensor located.
  15. Aug 19, 2017 at 7:59 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    The crank position sensor is on the front of the engine. It reads crank position for the computer. There is nothing that would click on it- non interference type of sensor. The rear diff is another story. Depends what they did, but more logical you may have an issue on that. Did they replace the gasket? Rear end? Nothing?
    Also - does the clicking occur faster as you drive faster?
  16. Aug 19, 2017 at 8:19 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
  17. Aug 19, 2017 at 9:48 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    You need to be a lot more specific. All speeds? Low speed? Does the frequency of the clicking change as you slow down? Does it happen while you turn, go straight, etc? About every piece on the truck can make some sort of clicking noise.
