Clicking Sound After Shifting Into D or R
Discussion in '2nd Gen. Tacomas (2005-2015)' started by qckslvr2234, May 13, 2011.
  1. May 13, 2011 at 12:00 AM
    qckslvr2234
    qckslvr2234 [OP] Well-Known Member
    Maryland
    06 Double Cab
    5100's at 2.5, taco lean spacer, Wheelers 3 leaf aal, sway bar relocate, Nitto terra grapplers 285/70/17, spidertrax, custom fishing rod holder, afe drop in filter, 15% tint on front 35% on back, access original roll up cover, BHLM, LED's in cupholder, Plasti-dip badges
    I have an 06 DCSB with 4.0L and automatic trans. I have been noticing that when I shift into drive or reverse as I start rolling I hear a clicking noise coming from under the truck. It is a single loud click sound just as I start to roll. My guess is it is coming from the transmittion but I cant figure it out. It happens mainly when I go from drive to reverse or reverse to drive. I have not noticed it yet when going from park to either gear.
    Any thoughts?
    Oh yeah truck has roughly 81,000 miles on it and all scheduled maintenance has been done to this point. Thanks for the help.
  2. May 13, 2011 at 12:34 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Oh wow, this sounds A LOT like what my manual tranny was doing (and if so it will get worse over time):
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/155957-6-speed-manual-grind.html
    I am not sure yet what actually broke (they said not to even get into it). I will hopefully find out tomorrow or saturday. But they are replacing my entire transmission system.
    Does it seem to happen more on bumps or maybe turns?
  3. May 13, 2011 at 1:43 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    OP - does it happen when the truck is cold? Hot? Both?
    Perhaps it's not the tranny at all, but slack in the driveline?
  4. May 13, 2011 at 1:54 AM
    qckslvr2234
    Maryland
    06 Double Cab
    It never happens that I know of when I am driving. It is mainly when I am in the driveway and switch from one gear to the next. As an example I pull in the driveway from the main street. The way my driveway is I have a spot that once I pull up I can back into on the side. The sound comes once I come to a stop, shift to reverse and start to move. As I start to move it makes a loud click. Just once and then it is over. The reason I said possibly transmission is that it is a loud click to wear you can hear something changing over and sounds as if it is not engaged all the way until after the click.
    Good point. I am not that knowledgable in drivelines though. It happens no matter if it is hot or cold. I come to a stop, shift from one to the other and start to move at that time it makes a loud click.
  5. May 13, 2011 at 2:38 AM
    StandingCow
    NJ
    Hmmm, ok, my issue would happen while you were in gear and driving. Nevermind then. :)
  6. May 13, 2011 at 5:10 AM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    But ONLY if you go from D to R or from R to D?
    What about when you go from L to 2 or from 2 to 3 or 4 to D?
    You said it didn't happen when you went from P to D or P to R, correct?
  7. May 13, 2011 at 6:32 AM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    Floating front rotors shifting front and back? My truck has done it since I had it. I start rolling and when I hit the brakes I get a single loud metal clunk. Put it in D and first time I hit the brakes it is the same thing.
  8. May 13, 2011 at 9:07 PM
    qckslvr2234
    Maryland
    06 Double Cab
    I have not tried to go through each gear since I never really deal with that. It only has happened when going from D to R or the other way, never in or out of park.
    Sounds similar but it happens as soon as I start to roll not when I hit the brakes. My brother in law has an 09 DCSB and I have never noticed it on his. Is this something easily fixable if it is the same thing?
  9. May 13, 2011 at 9:22 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    don't call me francis
    High Desert
    07 TRD OFFROAD 4x4 VSC/TRAC/DAC/HAC
    snugtop supersport canopy, black westin bullbar/tube steps, piaa offroad lights, weathertech floor mats, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Try greasing the drive line zerks to see if it helps.
  10. May 13, 2011 at 9:41 PM
    qckslvr2234
    Maryland
    06 Double Cab
    Might sound stupid but I dont know much about drivelines. Where are they on the driveshaft and about how many?
  11. May 13, 2011 at 10:30 PM
    OffroadToy
    High Desert
    Drive line/shaft...same thing. If you have 4WD there are 5 zerks total.
  12. May 13, 2011 at 10:32 PM
    qckslvr2234
    Maryland
    06 Double Cab
    Ok thanks I will be doing this next time I am off. Do you think the problem could be anything else?
  13. May 14, 2011 at 8:04 AM
    OffroadToy
    High Desert
    Since adding grease is easy I thought I'd throw that out there to see if it might help.
    I had a similar noise whenever I put the truck in reverse and backed out the driveway...a single "click". I then got in the habit of putting the truck in neutral and rolling back a few feet before going into reverse (driveway is at a slight incline) and I never here it anymore. I'm at a loss on what the exact cause was. Might be something with the brakes like viperstd mentioned?
  14. May 18, 2011 at 9:00 PM
    BayTaco
    BayTaco Well-Known Member
    Nor Cal
    08 TRD RT 4WD DBL CAB SB
    2.5" Lift, 265/75R16 A/Ts, aFe Pro Dry S, ARE Shell, Magnaflow
    OP, I have the same exact issue and while searching came across your post. Did you have any luck with greasing the driveshafts? I am still under warranty and had the dealer look at it. They said they couldn't duplicate the issue, but greased the driveshafts, but I still notice this! I am thinking of taking it back, anyone else have this issue with resolution? Thank you.
  15. May 18, 2011 at 10:32 PM
    qckslvr2234
    Maryland
    06 Double Cab
    I have not done it yet. I picked up some extra shifts so getting ready to finish up 10 days in a row. Anyways, it looks like monday will be my opportunity to do it. Let me know what happens with the dealership. I dont think it is a huge issue just annoying. I hope at least.
  16. May 18, 2011 at 10:52 PM
    Average JOE
    Average JOE Well-Known Member
    San Diego
    PreRunner
    3'lift,Upgraded sound system,Dyanamat interior flowmaster,K&N,
    Subbed. I have a 07 DC Prerunner.......... Same prob. One loud click. Only when shifting from D to R or R to D.
    Ill be watching this for info.
    thanks
  17. May 18, 2011 at 11:00 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I have and '06 and the same noise. I took it to a dealer about 3 years ago and they said it's normal. I asked what the noise was and how it occurs but he couldn't even explain it. Still have the noise 3 years later and no issues.
  18. May 18, 2011 at 11:02 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i have 07 trd OR 4wd DCSB. and today will be day 6 i have had it. i have NOT noticed this on mine. but maybe i just have not noticed it. i have 25'0**K miles
  19. May 18, 2011 at 11:03 PM
    qckslvr2234
    Maryland
    06 Double Cab
    Sounds like it is more common then I thought. My brother in law has an 09 and his doesn't do it. Hopefully someone figures it out for us.
  20. May 19, 2011 at 8:50 AM
    viperstd
    Maryland
    someone want to pull the front brakes off and try it out?
