Clicking Sound from Under Truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jan 9, 2022.
  1. Jan 9, 2022 at 9:14 AM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    When launch from a stop at at least half throttle a clicking sound can be heard. If accelerate slow the sound does not occur.
    Sounds like its coming from under the back seats.
    Suspect could be u joints on driveshaft but wondering if a bad pinion axle or something else in differential could also be making this noise.
  2. Jan 9, 2022 at 9:37 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I would definitely look under the truck and see how crusty the U joints and center bearing is
    Mark77 likes this.
  3. Jan 9, 2022 at 9:39 AM
    TacoBell07
    Four door 2wd Taco
    Does pinion gear or axles make this clicking sound too?
    Or is it mainly more a bad joint noise?
  4. Jan 9, 2022 at 9:40 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Sounds to me like a u joint issue. Start there,do you have a slight vibration when you first start out?
  5. Jan 9, 2022 at 9:45 AM
    TacoBell07
    Four door 2wd Taco
    No vibration when I start out. Sounds kinda like a baseball card clicking against a bicycle tire.
    But I've had a shuddering for years that happens when trying to maintain speed 20-50 mph at very light throttle. Replaced torque convertor few months ago so know shudder is not torque convertor lock up.
  6. Jan 9, 2022 at 9:46 AM
    TacoBell07
    Four door 2wd Taco
    Last replaced U JOINTS in 2016 they are Moog. I will probably try to get Spicer if I replace them all again.
  7. Jan 9, 2022 at 9:48 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Bad pinion or axle bearings wouldn't make a clicking noise, they would make more of a whining or grinding noise.
    I agree with the others, U-Joints would be first suspect for a clicking noise.
  8. Jan 9, 2022 at 10:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    Click or clunk when you back up? Bad U's often shift around with a change in rotational direction.
  9. Jan 9, 2022 at 10:19 AM
    TacoBell07
    Four door 2wd Taco
    You mean try backing up instead of driving forward to find a difference?
    It only happens when i take off fast from a stand still.
    Are you thinking I should go fast in reverse? Challenge accepted LOL
  10. Jan 9, 2022 at 10:23 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think he means just going from drive to reverse and vise versa if you hear a click or clunk.
    Clearwater Bill likes this.
  11. Jan 9, 2022 at 10:26 AM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    Someone zip tye your D/S?
  12. Jan 9, 2022 at 10:50 AM
    Bluenoser009
    Bluenoser009 Well-Known Member
    Alberta
    06 Tacoma (A-cab/TRD/SR5/OFF-ROAD/6 spd)
    Not sure if your 2WD has a Carrier Bearing like a 4WD does, but you could check that hardware to ensure it’s tight
    I agree with you and others that u joint is lead case. You could shoot them all with grease and see if it changes sound intensity at all. Might help narrow it down to that
  13. Jan 9, 2022 at 11:12 AM
    TacoBell07
    Four door 2wd Taco
    This is a Prerunner V6 and yes it has a carrier bearing because I changed it 4 months ago with a spicer factory replacement.
  14. Jan 9, 2022 at 11:13 AM
    TacoBell07
    Four door 2wd Taco
    The Moog u joints I have on there now are not grease-able but that sounds like a good idea.
    Bluenoser009 likes this.
  15. Jan 10, 2022 at 6:59 PM
    TacoBell07
    Four door 2wd Taco
    Put it in reverse and do not hear any noise backing up. The noise is only when take off fast from being stopped completely.
  16. Feb 21, 2024 at 2:37 AM
    Neilson
    Neilson New Member
    I know its been a while but I'm having the same issue. What was the cause of this?
  17. Feb 21, 2024 at 10:11 AM
    TacoBell07
    Four door 2wd Taco
    I think i had a u joint that had seized and binding because it was out of grease. It would not move around at all.
