Clicking Sound in Door/ B Pillar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco John, Oct 4, 2011.
  1. Oct 4, 2011 at 8:28 AM
    Taco John
    Taco John [OP] Well-Known Member
    Illinois
    4X4
    This is driving me nuts. I have a double cab with clicking sound somewhere around this area that I can't track down. It happens primarily with cab flex over bumps or stops and is worse with a trailer in tow. It sounds like maybe it is the seatbelt aduster/ locking mechanism, but if I pull and lock the seatbelt and hold it while driving, it will still happen. i also checked out the door latch, window trim, door seals and I just can't find the culprit.
    Any ideas?
  2. Oct 4, 2011 at 12:49 PM
    pinktaco808
    pinktaco808 Hot Steppa
    take off the plastic and put cheap dampener or expanding foam man
  3. Oct 4, 2011 at 12:56 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    ya... i have the same issue.
  4. Oct 4, 2011 at 1:48 PM
    Taco John
    Illinois
    4X4
    So you think it is the seatbelt adjuster?
  5. Oct 4, 2011 at 3:55 PM
    Taco John
    Illinois
    4X4
    I just took it apart and I still can't make it the adjuster. i did find a blue wire "elbow/ Grommet" type thing for the rear door that sounded suspiciously like the noise when touched so I used a little silicone when snapping it back into place. I hope that cures it.
  6. Oct 4, 2011 at 4:24 PM
    pinktaco808
  7. Oct 6, 2011 at 6:34 AM
    Taco John
    Illinois
    4X4
    That wasn't it. I am now convinced the sound it coming from the door - maybe a lock mechanism rod that is rattling around or something. I guess I will pop the door panel off next.
  8. Oct 6, 2011 at 6:54 AM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Probably the seat belt assembly adjuster...I searched high and low last year:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/74358-rattle-drivers-side-door.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/96958-anyone-fix-seat-belt-rattle-problem.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/5329-door-rattle.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/54539-driver-side-seat-belt-adjustment-rattle.html
    I saw a thread somewhere on here where someone made a shim out of a plastic milk jug and put it in to stop the rattle. I gave up on mine and just warning ya, it gets more annoying when it gets colder out.
  9. Oct 6, 2011 at 6:57 AM
    Bloodhound
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    While I was searching you posted this... I remember seeing someone found some loose bolts and had to tighten them up in the drivers door. FWIW, I can't "make" my seatbelt adjuster rattle but while driving that's the area mine is coming from...right in my freakin' ear.
