Clicking sound when turning wheel after off-roading
Discussion in 'General Tacoma Talk' started by armoured, May 17, 2024.
  1. May 17, 2024 at 11:57 AM
    armoured
    armoured [OP] Well-Known Member
    2020 OR DCSB
    Any ideas?
    This is after a 4 day off-roading trip to the owyhees. This only happens when I put on the brakes. If I put it in park and do this, no noise. Nothing looks out of place under the truck. Flat surface. This has never happen before, 2020 4wd shortbed.
    https://imgur.com/a/2jrchcJ
    It's loud to the point where all my neighbors and their kids stare at me as I pull into the driveway lol......
    wilcam47 likes this.
  2. May 17, 2024 at 12:13 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    My first though is loose cam bolts on the lower control arm(s). Not really loose, just enough that the cams and bushing sleeves are creeping back and forth under heavy load. Using front brakes adds to that load.
    Have a helper turn the wheel, crawl under and put your paws on those areas, and even on the ball joints and tie rod ends. Where you feel it the most is the source. Just watch for pinch points when you’re doing it.
  3. May 17, 2024 at 12:27 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Heat shield on brakes?
  4. May 17, 2024 at 12:28 PM
    wilcam47
    Will
    Bourbon state
    If you coast slow in neutral does it do that noise?
  5. May 17, 2024 at 12:29 PM
    wilcam47
    Will
    Bourbon state
    Or cracked strut spring? Just throwing darts here
  6. May 17, 2024 at 12:33 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Rock in heat shield/brake vents?
    Kolter45 likes this.
  7. May 17, 2024 at 12:35 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    rock in your caliper will do this too
