Clicking sounds from front end when in 4wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ozark_RegCab, Sep 9, 2023.
  1. Sep 9, 2023 at 5:00 PM
    Ozark_RegCab
    Ozark_RegCab [OP] Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Towards the end of my trip to Colorado, I started to notice a clicking noise when going over bumps or especially when the front end dipped down. It sounded loudest from the front driver side: a single click, like a socket wrench turning. The OEM CVs are fairly new with only 12k miles or so. Would it be possible they're already wearing out, it could it be something in the leaking steering rack?
  2. Sep 9, 2023 at 5:10 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Was the clicking present when turning while in 4wd? If yes, then you have a dry CV joint.
    Clicking while going straight is going to be something else .
  3. Sep 9, 2023 at 5:16 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I don't remember it being specifically while turning, but I did only notice it in 4lo. I think the wheels were relatively straight for at least some of the clicks.
    koditten[QUOTED] likes this.
  4. Sep 9, 2023 at 5:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Have you put it up on jackstands, pulled the wheels off, and narrow down the source of the noise?
    It's like every other "diagnostic" thread, you need to do some work yourself otherwise everything else is just a guess.
    koditten likes this.
  5. Sep 9, 2023 at 5:19 PM
    koditten
    Kirk
    Central Michigan
    Can you jack up 1 side at a time, spin the tire by hand and listen for clicks? Have the wheel turned and do the test as well.
    Kwikvette likes this.
  6. Sep 9, 2023 at 5:24 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea that'd be the next step, although I only noticed it when going over bumps or when the suspension was traveling, not just when driving down a flat road, so I'm not sure how much I'd learn from just spinning the wheel. It'd be worth a try though.
    I was just wondering if this was a common symptom with worn racks, since I know mine needs replacing anyway. I'm nursing it along with stop-leak for now.
  7. Sep 9, 2023 at 5:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nooooo
  8. Sep 9, 2023 at 5:34 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Well, I don't hear it whining anymore, and haven't noticed any drips, so it seems like it's doing its job :notsure:
  9. Sep 9, 2023 at 5:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It would whine if it was low on fluid, not because you added stop leak.
  10. Sep 9, 2023 at 5:37 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Well I guess it's stopped leaking then.
