Clicking sounds while braking at low speeds?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Navygreen99taco, Jun 21, 2025.
  1. Jun 21, 2025 at 9:09 PM
    Navygreen99taco
    Navygreen99taco [OP] New Member
    I have been having a issue with a clicking sound when i am braking at low speeds. only happens when i apply the brake. with slight vibration when braking. I have replace the rotors already, new brake calipers and pads, mostly all lower control joints and suspensions parts, replaced the rack and pinion, new shocks and struts, i cannot figure this out. any ideas or help
  2. Jun 22, 2025 at 6:50 AM
    02hilux
    Planet: EARTH
    Check your LBJ. A buddy’s Tacoma was clicking too when the brakes are applied and it gave him a great life experience going 70mph on the highway.
    Navygreen99taco[OP] likes this.
  3. Jun 22, 2025 at 2:53 PM
    Navygreen99taco
    i just recently replaced both sides Lower ball joint so im thinking it cant be that.
  4. Jun 22, 2025 at 3:29 PM
    02hilux
    Planet: EARTH
    but was the nice there prior to the LBJ changed?
  5. Jun 22, 2025 at 3:44 PM
    Navygreen99taco
    yes so the noise was there before i changed the LBJ and its still there. the only time i can pinpoint that i changed and then i started to hear the clicking sound was after i changed the calipers, brake pads n hardware. if tried two separate pads n hardware and still
  6. Jun 22, 2025 at 5:26 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Is the clicking rotational?
    I had a rock/rd debris stuck between rotor and brake shield.
    Put in reverse…hard acceleration…hard braking….knocked debris out
