clicking under dash and hood
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tobo, May 23, 2010.
  1. May 23, 2010 at 2:22 PM
    Tobo
    Tobo [OP] New Member
    Louisiana
    05 PreRunner SR5
    only have 31,000 miles on Tacoma. Parked it yesteday and all was well. Got in it last night and I got half a turn over and it went blank. ABS light is on and brake warning light is on. With key in pocket I have the clicking mentioned in title. I have no lights, no radio and avery week dome light. Battery is showing full charge. I have disconnected battery because only way I could get clicking to stop. Attempted to jump it off with no luck. I have never experienced anything like this so any help is much appreciated.
  2. May 23, 2010 at 2:34 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Just because the green light is glowing does not mean you have a good battery. You could have a bad cell. Although my car did start, when jumped. It had the clicking and clacking under the hood, when it was off. Good luck.
  3. May 23, 2010 at 4:34 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If you're experiencing this with the factory battery, get a new one! After all, you do have an 05. Those stock batteries last about 36 months. Anyone with one that lasted longer is very lucky. If it's a replacement battery, you would need to have it load tested to know whether it's good or bad.
  4. May 24, 2010 at 11:54 AM
    Tobo
    Louisiana
    05 PreRunner SR5
    Thanks to both you guys. You confirmed what I was thinking about in the early morning hours. Battery was deader than a hammer. Put new on in and all is well. Battery dealer says new batteries seldom give you warning they are getting weak. I find it strange it showed positive. But then my first car was a 1953 chevy bought in 1963. Kind of dating myself. Thanks again. I appreciate you both.
