"clicks" off the line when accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skyddskar, Jun 16, 2014.
  1. Jun 16, 2014 at 3:51 PM
    Skyddskar
    Skyddskar [OP] Member
    Socal
    '07 PreRunner Access Cab
    *Update 10/1 Dealer diagnosed as either ujoints or driveshaft splines. IOW they have no idea
    Hey all,
    Im a new member here at Tacoworld and just want to say the technical information on this board is fantastic and thanks!
    To business... So I have a 2007 access cab Tacoma TRD-offroad with a 6-speed manual and completely stock. When Accelerating from a stop, there are 2 obvious clicks that occur each time when starting. Both clicks do not sound the same and are definitely coming from the front of the truck. I think each click is coming from one side, meaning there is a click from the right front and a click from the left front (hence the difference in sound). This occurs when starting in both first and second gear and is more obvious when accelerating harder. It seems to go away during slow acceleration. Im not sure if I am noticing this more because i drive the truck more or if it is getting louder.
    I believe i have narrowed the possibilities to a bilateral suspension component in the front or the brakes since this seems to be caused either 1) after braking, or 2) after oscillations in the front suspension during initial acceleration.
    After doing some searches on this sight it seems there are reports of something similar occurring from the brake pads or actuators realigning themselves?
    Any input or experiences with this problem would be greatly appreciated. Thanks for your time and input!
  2. Jun 16, 2014 at 5:31 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    I have a click and so did my friends 06 tundra. His was from the carrier bearing. Mine is from the leaf pack according to toyota tech. I have heard of people hearing clicks on the front of the truck caused by the aluminum bumper torquing. Not sure what other front end clicks are known.
  3. Jun 16, 2014 at 5:38 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Welcome !!!!
    Did you check your motor mounts and associated bolts ???
  4. Jun 16, 2014 at 8:17 PM
    Skyddskar
    Socal
    Although I haven't visually checked the mounts, I ruled them out because when holding the brake and giving gas (in first gear) there was no clicking. I would think if it was a mount I would be able to replicate this clicking during this test.
  5. Jun 17, 2014 at 8:36 AM
    Canufixit
    New England
    Just a thought .... Flywheel (cracked?) or clutch plate/bearing clicking??
  6. Jun 17, 2014 at 9:20 PM
    Skyddskar
    Socal
    so like a previous poster said, toyota said it was the leaf springs. Specifically, that they needed lubrication. The problem is better now, but no completely gone. Hopefully it will go away when i put some dakars on next month.
  7. Jun 18, 2014 at 12:07 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Noises are hard to track. My click on takeoff sounded like it was coming from the front. I turned out to be a rear u-joint.
  8. Jun 18, 2014 at 2:21 PM
    Skyddskar
    Socal
    Did you have two separate and distinct clicks only noticeable at take off?
  9. Jun 20, 2014 at 4:41 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Two, but close together. Ujoints are easy to check. Separate the flanges, and check their movement. Any slop, or hard spots=replace.
