Climate control console problem - AC not turning off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mctaco11, Nov 21, 2014.
  1. Sep 15, 2018 at 3:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    So everything is working properly, you are just stuck with the AC on and cannot turn it off? And you have already replaced the Control panel in the dash where the knobs, A/C and Recirc push buttons? If so then that seems to narrow it down to either wiring or the A/C Amplifier.
  2. Sep 15, 2018 at 4:30 PM
    skiracer0112
    skiracer0112 Well-Known Member
    Bryan
    Breckenridge, CO
    '11 Silver Double Cab 6-speed TRD OR
    Yes, I am thinking that maybe the control panel I ordered is also defective since it was from a salvage but am debating on trying the amplifier first since the control panel is so much more $$$.
  3. Sep 15, 2018 at 5:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the clutch is cycling then what is the problem? Do you have cold air coming out when the setting is on hot? Are you wondering why the clutch comes on when the setting is on windshield defrost?
  4. Sep 15, 2018 at 6:23 PM
    skiracer0112
    Bryan
    Breckenridge, CO
    The A/C can not be turned off, if the fan is running only cold air will come out despite the temperature setting and the A/C light remains illuminated. I was soliciting suggestions to troubleshoot before paying almost $1000 for a new control panel which now is what I am thinking it probably is.
    b_r_o[QUOTED] likes this.
  5. Sep 15, 2018 at 8:45 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    So the a/c light is on all the time?
    Have you checked the blend door?
  6. Sep 15, 2018 at 9:04 PM
    skiracer0112
    Bryan
    Breckenridge, CO
    Yes it is. I haven’t checked it but I will tomorrow, thanks!
  7. Oct 1, 2018 at 9:36 AM
    skiracer0112
    Bryan
    Breckenridge, CO
    Thank you everyone for your input and suggestions! It ended up being a failed control panel that was fixed this weekend with a new OEM Panel! No more bundling up for my 45 minute commute to work!
    b_r_o likes this.
  8. Oct 1, 2018 at 4:20 PM
    Jimmyh
    SC
    2012 Prerunner SR5
