Climate control fuse keeps blowing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ccelman, Feb 1, 2024.
  1. Feb 1, 2024 at 3:28 PM
    Ccelman
    Ccelman [OP] Member
    Vancouver BC
    16 tacoma dcsb trd sport blue 6spd
    Old man emu lift kit JBA UCAs 285/70/17 ko2s
    I've got a 2016 Tacoma TRD sport 5spd manual. They 10amp fuse under the dash would blow every now and then recently but now it blows instantly everytime.
    If I unplug the blower motor and swap the fuse it doesn't blow
    I've seems posts where it's related to heated seats or the BSM sensors in the bumper
    Any help would be appreciated
    Also my climate control has the auto function in case that matters.
  2. Feb 1, 2024 at 3:33 PM
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    Seems to be something like a short happening somewhere. Have you traced the wires from the blower to the fuse at all and checked for damage? The blower motor itself could have a short internally causing "infinite" amp draw upon starting. Any odd noises from the blower motor? If you can pull it out and hook it up to an independent power source and test the blower, that would be optimal.
    Side note, do you mean 6sp manual or did the 16's really come with a 5sp for a minute??
    Dead-Weight likes this.
  3. Feb 1, 2024 at 3:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like a bad blower motor
  4. Feb 1, 2024 at 3:47 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Does the truck have any electrical mods?
    Chew likes this.
  5. Feb 1, 2024 at 4:00 PM
    Ccelman
    Ccelman [OP] Member
    Vancouver BC
    To be honest I don't know how to do any of that lol. And no noises at all.
    I've seen/heard the noises the '17s get
    Sorry I meant 6spd manual
  6. Feb 1, 2024 at 4:01 PM
    Ccelman
    Ccelman [OP] Member
    Vancouver BC
    Some fog lights that are plugged into OEM and never use
    shakerhood[QUOTED] likes this.
  7. Feb 1, 2024 at 4:03 PM
    Ccelman
    Ccelman [OP] Member
    Vancouver BC
    Also to note my driver's side heated seats haven't been working for a few months prior to this
    As well my BSM hasn't worked in years lol
  8. Feb 1, 2024 at 4:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you disconnect a component from the system and the fuse stops blowing you pretty much just diagnosed the problem
  9. Feb 1, 2024 at 4:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    what fuse is it?
    shakerhood likes this.
  10. Feb 1, 2024 at 4:14 PM
    TnShooter
    Deogee
    STOCK
    Yeah. Typically, But a 10A fuse for a blower motor? Seems you'd need one larger than 10A?
    I'd still like to know what fuse it is.
    Wrong fuse size in the blower motor fuse location?
    Rednecktacoma22 likes this.
  11. Feb 1, 2024 at 4:37 PM
    Ccelman
    Ccelman [OP] Member
    Vancouver BC
    Controls the heated seats, heated mirrors, climate control the LCD display and the temperature display on the dash.
  12. Feb 1, 2024 at 6:13 PM
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    This was going to be my next suggestion as well op
    TnShooter[QUOTED] likes this.
  13. Feb 1, 2024 at 9:22 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    '16 & '17 4cyl had an optional 5spd trans... it was dropped in '18
  14. Feb 1, 2024 at 9:27 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    If you unplug the fan and then control anything else on the circuit, does the fuse blow again. If not then replace the fan. If it still blows then start tracing whatever caused the fuse to blow.
    There has been issues with the power supply to the heated seats from some people. The wiring burns up at the connector. This could cause a dead short.
  15. Feb 1, 2024 at 9:57 PM
    TnShooter
    Deogee
    STOCK
    That fuse goes to a bunch of things.
    It doesn’t go directly to the blower motor that I can see.
    But it goes to things associated with the blower motor.
    And depending on whether is and Auto or Manual it goes to different place.
  16. Feb 2, 2024 at 5:53 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    You are right... it goes to a some relays, servos and the A/C amplifier.
    Screenshot_20240202_054026_Drive.jpg Screenshot_20240202_054042_Drive.jpg Screenshot_20240202_054100_Drive.jpg Screenshot_20240202_054119_Drive.jpg Screenshot_20240202_054251_Drive.jpg
  17. Feb 2, 2024 at 6:07 AM
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    ^ this right here is what makes this community the greatest.
    TnShooter and Kodiak420 like this.
  18. Feb 2, 2024 at 6:47 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A/C magnetic clutch is suspect for a short
  19. Feb 23, 2024 at 7:49 AM
    Ccelman
    Ccelman [OP] Member
    Vancouver BC
    Update: I replaced the blower motor and everything worked great for about 2 weeks.
    And now the fuse as blown again this morning...
  20. Feb 23, 2024 at 10:02 AM
    TnShooter
    Deogee
    STOCK
    Have you read the above post?
    I was kind of expecting this, as the blower motor doesn't run off that fuse.
    Again, see above post to start diaging,
    I'd start with pulling the Magnetic Clutch Relay.
    (FWIW, I am NOT saying it's the relay) I'm suspecting the clutch.
    The relay will kill the power to the clutch.
    BTW, you wont have A/C when you pull the relay.
    If the fuse doesn't blow. Clutch time.
    If it still blows, resort to stuff tied to that fuse in the diagram above.
    Speedfreak and Chew like this.
