Climate Control Illumination Lights Out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cavusvs, Sep 7, 2020.
  1. Sep 7, 2020 at 9:53 PM
    cavusvs
    cavusvs [OP] Member
    2017 Tacoma Limited
    Has anyone experienced the climate control illumination light going out when the headlights are turned on on the 2017 Tacoma Limited? When the lights are off, everything is illuminated ( seat heater setting, fan speed etc.) When the lights are on that panel is completely dark as well as the lights in the door window switches. Any ideas on what may be the cause?
  2. Sep 8, 2020 at 3:11 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Black knob on the instrument cluster (trip meter reset button) turn it to the right and hold...you can adjust the brightness from there.
    Chew and Tullie D like this.
  3. Sep 8, 2020 at 6:21 PM
    cavusvs
    cavusvs [OP] Member
    2017 Tacoma Limited
    Thanks Ronzio, but the illumination on the control panel is still out. The speedometer and rpm gauges dim with the knob, but not the control panel.
  4. Sep 8, 2020 at 6:38 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Just gonna state the obvious here, but have you checked the fuses under the dash? Seems like a logical first step.
  5. Sep 8, 2020 at 8:44 PM
    cavusvs
    cavusvs [OP] Member
    2017 Tacoma Limited
    Checked all of the fuses with a volt meter and they are ok. Everything is ok until you turn on the lights and some lights go dark. There must be a relay somewhere.
