Climate control potentiometer part?
Discussion in '1st Gen. Tacomas (1995-2004)' started by brian1649, Feb 25, 2020.
  1. Mar 4, 2020 at 11:14 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    What does the mounting for this thing look like? Is it just soldered to the board or does it have a nut holding it in the panel?
    I don't see any 2.7k pots, but you could try a larger resistance, like 3.5k or 4.2k. If it is held into the panel via a nut, you could run wires to the holes where the old one soldered in.
  2. Mar 6, 2020 at 9:37 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    This is the closest thing I ever found.
  3. Mar 6, 2020 at 10:14 AM
    brian1649
    brian1649 [OP] Well-Known Member
    Well I don't have the original part in front of me, but that looks pretty damn close. Any reason why you thought it wouldn't work? The 2.5k version should work electrically
  4. Mar 6, 2020 at 5:14 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    6 pin and its a few mm larger. Pins don't line up up the same.
  5. Mar 8, 2020 at 3:54 PM
    Yoda2002
    Yoda2002 Member
    2002 crew cab
    I’m having the same problem with my 2002. Been happening for about 8 months now.
    Jimmyrace likes this.
  6. Mar 8, 2020 at 5:56 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    FWIW, I just checked my ‘04 and it has discrete steps. Wish I had seen this earlier I just had the dash apart this morning to connect a mic for hands free.
  7. Mar 8, 2020 at 7:19 PM
    brian1649
    That's great to know. If you happen to be back in your dashboard, it would be great to get some resistance measurements on that bad boy to figure out if it can be swapped for the older continuous potentiometer
  8. Mar 14, 2020 at 4:24 PM
    brian1649
    So an update from my research, my 2003 celica which has discrete steps seems to use some sort of geared mechanism - totally different. In my research online looking at other toyota models of similar years, it seems like most were using this as well. I only found that the highlander also has the potentiometer, which is likely why the kit that kirby J posted is for.
    I reached out the Dorman (the manufacturer of that kit) to try to get information on the potentiometer or to see if they would sell just the potentiometer, but they wont give me shit. (big surprise)
    I reached out to Toyota as well, although I doubt that will go anywhere
    Jimmyrace and jammer like this.
  9. Mar 14, 2020 at 5:33 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    And people say we over react about tech creeping in.
  10. Jul 6, 2020 at 7:45 AM
    tacojim02
    tacojim02 Well-Known Member
    Puxico, Missouri
    02 dbl cab trd
    2in suspension lift
    Okay I know this may sound redneck, but I fixed my issue with a zip tie. the inlet hose to the heater core has a cable operated valve that closes when in cool and opens when heating. I removed cable and zip tied valve closed. when winter time gets here I will reconnect cable and cut zip tie.
  11. Jul 6, 2020 at 7:52 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    I think the whole OEM climate control is still available for about $105
  12. Jul 6, 2020 at 7:56 AM
    tacojim02
    Puxico, Missouri
    02 dbl cab trd
    2in suspension lift
    really I thought I read on here that you couldn't get them anymore from Toyota. Oh well she is blowing cold all the time now lol.
  13. Jul 6, 2020 at 7:59 AM
    smithlaketaco
    Houston, Al
    I did a quick google search for 2002 tacoma oem climate control and it shows different dealers and gave me the option to order one. My 02 has been doing it but when you push on it, it goes cold again. So i have just put off changing it....
    Jimmyrace and tacojim02 like this.
  14. Jul 6, 2020 at 4:40 PM
    brian1649
    I ended up just finding a used one cheap on ebay. I intended to have to pull it apart and attempt a repair (was thinking about trying to replace the carbon ink) but turns out the used one from online works well
    I also needed a new bulb behind one of the gauges so that worked out well
    tacojim02 and Jimmyrace like this.
  15. Jul 16, 2020 at 11:36 AM
    #35
    Jimmyrace
    Jimmyrace Well-Known Member
    JR
    Louisville, KY
    Betty '03 Taco MTM Xtra-cab DLX 5VZFE
    OME struts / springs / leaf pkg :: SPC upper A ::
    Been having this issue for about a solid 9+ mo's now - I think I will just be changing out the whole unit as well - still a few available over on the ebay
    #35
  16. Jul 17, 2020 at 9:32 AM
    #36
    Jimmyrace
    JR
    Louisville, KY
    did same yesterday - it should be here in a few days
    #36
    tacojim02 likes this.
  17. Apr 3, 2021 at 10:33 AM
    #37
    jdleckenbyFF
    jdleckenbyFF Active Member
    JD
    2002 3.4 4x4 TRD Tacoma
    Any updates on your eBay control panel unit? I just ordered one off eBay. Having same issues as you all. Hoping it comes in soon and all works well when I install it.
    #37
  18. Apr 3, 2021 at 6:58 PM
    #38
    brian1649
    Mine worked well. It's just going to be hit or miss if the temp control potentiometer is worn out or not. It would be great to have a more permanent fix or a source to buy the specific component from
  19. Apr 27, 2021 at 1:27 PM
    #39
    Jimmyrace
    JR
    Louisville, KY
    ahhhh yeah ... havent chkd in here in a few i guess. Yeah mine works Well - gotta pay attention as to the part number whether it designates green or orange back lights & filters ... i ended w/ a green even tho wanted orange - so i just tore it all apart & inserted all the orange parts i could and reassembled ... the only remaining green is the a/c & recirc buttons ... and tbf i kinda like it.
    #39
  20. Dec 21, 2023 at 5:50 AM
    #40
    Tsean
    Tsean Well-Known Member
    Tsean
    Could you please send me the picture what have you done? I’m having the same issue as well. I have set it up right now. I can’t even touch it until knops. If I do touch and it will mess up my cold temperature I live in Florida I need to extremely AC thanks
