Climate Control/ Radio Surround Vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco John, Dec 3, 2009.
  1. Dec 3, 2009 at 10:49 AM
    Taco John
    Taco John [OP] Well-Known Member
    Illinois
    4X4
    My 09 has a vibration from the climate control/ radio surround when the weather gets cooler that is just driving me nuts. I think I can correct it easily enough with some carefully placed silicone, but I am not quite sure how to disassemble that stuff without breaking or marring anything. It looks to me like it is probably clipped in and should just pull out. Anyone pulled this apart on a Gen 2 for a radio installation or something?
  2. Dec 3, 2009 at 11:26 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    The climate controls pop out of the dash with a little work. This is the first step, use a small slotted screwdriver with a taped end. This will prevent damage when you are prying a little. Just carefully pop it out, might take a little bit to get the hang of it.
    Once out, you'll see two 10mm bolts holding the radio in. Theres two more a little deeper behind them as well, you'll need an extension on a socket to get them.
    Good luck with your rattle.
  3. Dec 3, 2009 at 1:32 PM
    Taco John
    Illinois
    4X4
    Thanks. It is the little things like that rattle that drive me nuts!
  4. Dec 3, 2009 at 1:49 PM
    JAG
    JAG Well-Known Member
    One thing i had to do was... take the middle knob off by pulling out on it. Then you can stick something behind the controls and it will pop out. :rolleyes:
