Climate Control Switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sju350, Dec 29, 2017.
  1. Dec 29, 2017 at 10:17 AM
    sju350
    sju350 [OP] Well-Known Member
    Joe
    TN
    18 Tacoma TRD Smokin Edition
    Does anyone know if you can put a climate control switch from a 2010 truck into a 2007, the plugs look the same. The only difference I see is the 2010 switch has a max ac marked just below the cold side on temp switch and my 2007 doesn’t
  2. Jan 18, 2020 at 3:05 PM
    prone2xl
    prone2xl Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
    @sju350 wondering this myself. did you ever find an answer ? I've seen some threads on people changing the controls from the 2012 models up and having to jump some wire or something but I would also like to change this part since I found one that's black. did it work if u tried it ? thanks...
  3. Jan 18, 2020 at 3:53 PM
    sju350
    Joe
    TN
    I tried it but it didn’t work correctly. If you had it turned for cold air, hot would come out and vise versa. If you set it to heat then cold air come on. There was a post somewhere on here saying you had to solder something but I wasn’t comfortable doing it so I just kept my original unit in
  4. Jan 18, 2020 at 4:11 PM
    prone2xl
    Mississippi
    thanks.. I was afraid of this. wish I had found u before I placed the eBay order lol... here's hoping I can cancel it or I guess i'll return.. I found some black ones for 05-08 and should have pulled the trigger on those but this one 09 one was like $50 cheaper... so frustrating.
  5. Jan 18, 2020 at 10:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you feel like trying to convert it yourself?
    Here is a great DIY by @3378jakesr5
    https://www.tacomaworld.com/threads/12-15-climate-control-in-a-05-11-truck-wiring-guide.411534/
  6. Jan 18, 2020 at 10:30 PM
    prone2xl
    Mississippi
    It’s weird. Bc the one I bought is an 09 climate control. Not the 12-15. But it still won’t work bc it has the max/cold wording on it ? So mad i didn’t check this out thoroughly before pulling the trigger on eBay
