Climate Control/TechStream Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frank_Zuccarini, Aug 15, 2018.
  1. Aug 15, 2018 at 11:29 AM
    Frank_Zuccarini
    Frank_Zuccarini [OP] Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Hi.
    I own a 2016 OR TRD. I also have the cracked TechStream version often mentioned in this 3rd Gen forum.
    I use the climate control manually, and whenever I push the A/C button, it simultaneously puts the system into 'recirculation'. I do not like this, as it takes longer to cool the car down when it is already piping hot from being locked up and sitting in the sun. I'd rather the truck bring in fresh air, and exhaust hot air, without me having to deactivate the recirc button.
    I have tried using TechStream to change this configuration, so that the 'recirc' does not come on whenever I use the 'A/C' button. But for the life of me, I cannot find the correct parameter to change.
    Does anyone know if :
    1) The 2016 model year does not allow for what I want
    2) My older, non-updated of TechStream cannot allow for this change, or
    3) I simply cannot find the correct sub-menu within TechStream
    Thanks for your help......................... Frank
  2. Aug 15, 2018 at 11:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    As a side note..........
    Outside ambient air is maybe 25* cooler. So driving with windows down for about 2 minutes will bring the cab down to ambient.
    Just tossing that out in case the Techstream solution is a no go.
  3. Aug 15, 2018 at 12:33 PM
    Natnewt
    Natnewt Well-Known Member
    bugs me too
  4. Aug 15, 2018 at 12:40 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Something along those lines is available in the entire headunit settings, I forget exactly that it is though
  5. Aug 15, 2018 at 12:51 PM
    Frank_Zuccarini
    Frank
    Chicagoland
    Yes, I do that now, thank-you.
    It really bugs me that Toyota chose to NOT let ME decide if I want it on recir or not. Also, that some supposedly well-meaning engineer got it ass-backwards about the fastest way to cool down the cab, and further decided that the owner is not clever enough to decide for him/herself.
    Again...................... Thanks
  6. Aug 15, 2018 at 12:54 PM
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    I also would like to change this
  7. Aug 15, 2018 at 1:57 PM
    CountofQ
    CountofQ Well-Known Member
    Duluth, MN
    2017 'Old Man Tan' AC OR
    I think the head unit setting is an automatic on A/C, not the automatic recirc.
  8. Aug 15, 2018 at 3:00 PM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    I've got the manual climate control, and depending on OAT (outside air temp) mine goes in to recirc or not when turning the A/C on. Cooler temps, not on.
  9. Aug 16, 2018 at 6:22 AM
    Raistlen0
    PA
    Maybe your right. I thought I was just crazy but I had remembered it not turning on but the last few months it always did turn on the recirc so now I am not sure
  10. Aug 16, 2018 at 8:08 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Mine always goes to recirculation when I turn it on too.
