climate controls- fan control switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by emhrobot, Mar 6, 2013.
  1. Mar 6, 2013 at 5:09 AM
    emhrobot
    emhrobot [OP] New Member
    westminster, colorado
    06tacomatrd,894runner
    I have an 06, the fan control switch is not working properly. It is working, in the "full blast" setting. The two mid settings are not working. Has anyone got a creative fix for this?
  2. Mar 6, 2013 at 5:18 AM
    BamaToy1997
    Bill
    Navarre, FL
    More than likely you are looking at the resistor pack. It is located under the right side of the dash. You will see 4 wires, white w/black, blue w/black, white w/blue, and green w/yellow. You can test it by measuring to see if there is resistance by removing the connector, then testing for resistance between terminal 1, and 2, 3 and 4 of the resistor (Not the connector). You should show a different resistance between them. Don't worry about resistance between say 2 and 3, or 3 and 4. If you get no resistance, or an open between terminals 1 and any of the others, then the resistor pack is bad.
  3. Mar 6, 2013 at 7:11 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Had the same issue on my 05. Took it in under the certified used warrenty and stealership fixed it dont remember what the cause was, but if you still have a warranty I would try that route. I want to say I remember something about a resister being involved, but at the time I didnt really care what was wrong, as long as they fixed it.
