Clinking noise on my tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Andrewsrey206, Jan 1, 2019.
  1. Jan 1, 2019 at 12:13 PM
    Andrewsrey206
    Andrewsrey206 [OP] New Member
    2019 Toyota Tacoma TRD OR
    Hey guys! I need help on this. Everytime I drive over a little bump I hear like a clinking noise on my front drivers side wheel/area. Do you know what that might be?
  2. Jan 1, 2019 at 12:14 PM
    caribe makaira
    Caribbean, Puerto Rico
    I'll take first guess....cab mount loose.
    Andrewsrey206[OP] likes this.
  3. Jan 1, 2019 at 12:15 PM
    Andrewsrey206
    Would I need to get it checked asap?
  4. Jan 1, 2019 at 12:17 PM
    SpeySquatch
    2016 TRD OR DCSB
    Could be a sway bar link, LCA bushing, or a cab mount
    If you have aftermarket leafs (Dakars) it’s common for the leaf to shift at the front mount and slap the metal where the military style bend in the leaf is. Mine did this and it made me crazy sounding like something was breaking
  5. Jan 1, 2019 at 12:18 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Welcome to TW. Usually if you put "Help" in your title that means you are stuck on a trail or something serious.
    There could be a hundred thing causing your noise. We need more info.
  6. Jan 1, 2019 at 12:25 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Welcome to TW, and please change title.
    Now for the noise, it could be numerous possibilities, including something you have in one your storage areas. Check to make sure you do not have any loose items in your cubby, or cup holders and such and then do a quick look at any nuts/bolts in that wheel area. Since you have a new truck I wouldn't touch a whole lot and let the dealer check it out, this way it gets documented just in case you need to refer back to it later on.
  7. Jan 1, 2019 at 12:34 PM
    Andrewsrey206
    Thank you guys for the help!
    hiPSI likes this.
