Clinking noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GioS_11, Oct 9, 2021.
  1. Oct 9, 2021 at 7:40 PM
    GioS_11
    GioS_11 [OP] New Member
    Gio
    2014 white Tacoma
    Can’t figure where the noise is coming each time I hit a bump on the road I get this clinking noise coming from the front tires.
  2. Oct 9, 2021 at 7:56 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Most likely its your front control arms; very common issue. Either worn bushings or the control arm isn't torqued on properly where it mounts to the chassis underneath. I had the same issue, turns out it was the lower control arm bolts not torqued properly. Others who have the same issue has also discovered that it was the bushings that has worn. Tape a video camera(GoPro/Phone) under the truck, point it to the lower control arm and go over speed bumps. You'll find out right away usually.
  3. Oct 9, 2021 at 8:07 PM
    GioS_11
    Gio
    2014 white Tacoma
    Okay I will have to check on that and strap the go pro to see exactly where the noise is coming from thanks.
    here is a video link of what noise it’s making
    https://youtu.be/J7Dkdi8LaIs
  4. Oct 9, 2021 at 8:10 PM
    httuner
    I meant Front LOWER control arms, just to avoid any confusion. Mount the Go-Pro down low and point it watching the movement of the front lower control arms.
  5. Oct 9, 2021 at 8:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Might be the brake pads jumping in the calipers. Gently touch the brake pedal the next time you go over a bump and see if the noise is still there.
    Also check the sway links, with the truck on the ground. Or even better, if you don't mind the extra work, disconnect them completely and ziptie them up out of the way.
    Gtlegacy likes this.
