Clock and head unit doesnt work.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scosh, Jun 8, 2010.
  1. Jun 8, 2010 at 6:48 PM
    Scosh
    Scosh [OP] Well-Known Member
    Scotty
    New Iberia
    02 Prerunner SR5
    Bilstein 5100's all around, Limo Tinted windows, Moto Metal 951 wrapped in Revo 2's 265/70/16, clear corners, dual Magnaflow muffler, Turn signal mod, more to come...
    The little clock by the steering wheel does not come on whenever I turn on my truck and my head unit just doesnt turn on at all. Anyone know what the problem is? I know the head unit may be a blown fuse, but Idk whats the deal with the clock.
  2. Jun 9, 2010 at 10:11 AM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
    check your fuses...
    i recently shorted my ignition wire and blew the 40 am1 fuse...
    the clock and radio didnt work, but a lot of other stuff didnt work also, but I'd say check the 40 am1 fuse that is a great starting point...
    from their check all the other fuses...
  3. Jun 9, 2010 at 12:33 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    The fuse would be the first place I would check.
    Side note: Little know fact. My '98 is an ext cab with the TRD package. Power windows and power door locks.... yet it didn't come with a clock. Which I'm fine with now because that spot makes the perfect location to mount a CB mic :D
  4. Jun 9, 2010 at 12:36 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Clock and radio are on the same circuit. If I remember correctly, so are the power outlets(12v). Under left dash coin holder.
  5. Jun 9, 2010 at 12:39 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    There are two fuses used by both the clock and radio on a 2002 Taco:
    - 15A DOME
    - 15A ACC (Accessory)
  6. Jun 9, 2010 at 12:42 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    Sorry about the sidetrack but.... Your taco has a clock?! I got screwed.
    Oh yeah, probably a fuse problem
  7. Jun 9, 2010 at 1:58 PM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
    Yeah it does, haha.
    But anyways I got it guys, it was the 15 ACC.
  8. Jun 9, 2010 at 2:04 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    nice... glad its fixed
  9. Jun 9, 2010 at 2:07 PM
    bama trd
    bama trd Well-Known Member
    Alabama
    2007 Silver Tacoma TRD Off Road
    Painted Grill with painted Land Cruiser emblem,Tinted Windows, BF Goodrich AT 275/70/17's on 4 Runner SR5 Rims, Bilstein 5100 front and Rear, debadged, fog light on anytime mod,
    just call FLAVOR-FLAV- I'm sure that he has an extra clock that has hung around his neck:laugh:
  10. Jun 9, 2010 at 5:20 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Something causes fuses to blow. Short or overloading, unless there's corrosion in your fusebox, that's it. Fuses don't go bad. Make sure you find out the cause, or you'll continue to blow fuses. Don't put a bigger fuse in, unless you like smoke.
