Clock/ECU resetting?
Discussion in 'Technical Chat' started by MGRS, Aug 3, 2009.
  1. Aug 3, 2009 at 4:12 AM
    MGRS
    MGRS [OP] Well-Known Member
    08 6spd TRD 4x4
    Four times in the last 20 days, my truck (08 6spd) has reset the clock on startup. I also disable the seatbelt chime and that also comes back on each time the clock resets.
  2. Aug 3, 2009 at 5:02 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Possible loose/bad ground connection?
    This is a new one, I have never heard of this happening.
  3. Aug 3, 2009 at 12:13 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Whatta you mean when you said ....
    Have you done any modifications recently?
  4. Aug 3, 2009 at 12:14 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You can disable the chime with the OD reset button. There is a sequence to do it.
  5. Aug 3, 2009 at 12:17 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    here it is Jan
  6. Aug 3, 2009 at 1:58 PM
    Janster
    Jandy
    Lancaster, PA
    I wasn't necessarily looking for that information myself.
    Just curious what exactly he meant and if he did any modifications lately that could've screwed something up....or caused a loose connection or something.
  7. Aug 3, 2009 at 6:36 PM
    MGRS
    08 6spd TRD 4x4
    Thank you for the responses. I used the above quoted sequence to disable the chime. It does, however, disable the passenger side without you having to sit in the seat.
    No wiring or electrical mods other than installing a Yaesu 1802M FM radio in the truck. I ran the wiring (protected in that black tube stuff) directly to the battery terminals. Actually, I think I will check again and make sure the connections are tight. That is the only radio-related install I could see being the culprit as nowhere do the radio wires touch anything else. The radio was installed for 5 months before this came up.
    This trouble first started when I cranked the truck as normal one day and the engine seemed to catch. I turned the key off 'start' and the truck died. That was the first time it happened.
  8. Aug 3, 2009 at 6:46 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I bet you didn't properly fasten the legs of those battery cables in correctly- thats what it sounds like. A lot of the radio guys I talk to would say that the best way to wire your radio is to take your positive off of a cigarette lighter and send negative to ground. That radio draws 10A +- peak.
