Clock spring/steering question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by victoriamatt, Jul 25, 2021.
  1. Jul 25, 2021 at 2:35 PM
    victoriamatt
    victoriamatt [OP] Member
    Fort McMurray
    2011 TRD Access cab
    Hi all,
    I recently damaged my clock spring cable while replacing my steering rack so need to replace it.
    When I installed the new rack I must have been off a few teeth when I reconnected my steering linkage to the rack and now my wheel is off a few degrees to the right when my wheels are straight.
    My question is, instead of having to disconnect the linkage from the rack again which is a pita, can I just reinstall the steering wheel level when I do the spring or will I throw off something (sensors, steering etc.).
    Cheers
  2. Jul 25, 2021 at 2:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have an airbag light on or how are you determining the clockspring is dagamed?
    Every vehicle I've seen with an airbag the steering wheel can only be installed one way onto the shaft.
    If it's not off much (probably less than 1/8 turn) an alignment shop can center it using the tie rod adjustments on the rack, otherwise you will have to disconnect the steering shaft and center it properly.
  3. Jul 25, 2021 at 4:26 PM
    Shawner1974
    Shawner1974 Well-Known Member
    Shawn
    CNY
    2012 Base Tacoma 2.7. 5 spd Regular Cab
    I had the clock spring replaced when I purchased my 12 Tacoma base regular cab. The tech must not have been paying attention, because when I got the truck back, the steering wheel was off center to the right when going straight. I ended up taking the air bag out and pulling the steering wheel and indexing it one tooth on the shaft splines. Was perfect after that. Wasn't a tough job to do as long as you have a puller.
    12TRDTacoma likes this.
  4. Jul 25, 2021 at 10:37 PM
    victoriamatt
    Fort McMurray
    2011 TRD Access cab
    Airbag light on and loss of all steering wheel controls, seems to fit the bill. From the videos I’ve seen the steering wheel is toothed and the shaft splined. I just wasn’t sure if there were any sensors or anything that indexing the wheel over would throw off. Thanks
  5. Jul 25, 2021 at 10:39 PM
    victoriamatt
    Fort McMurray
    2011 TRD Access cab
    Thanks, that sounds exactly like my wheel so sounds like I can just index it a few teeth till it’s straight.
  6. Jul 25, 2021 at 10:40 PM
    victoriamatt
    Fort McMurray
    2011 TRD Access cab
    Thanks for the info guys
  7. Jul 25, 2021 at 11:19 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Yeah it's easy to do it's a 3/4 (19mm) nut for the wheel itself under the airbag and a T25 or T30 IIRC to remove the airbag retainer bolts themselves.
    I've done it a few times for various reasons.
    You don't need a puller just squirt a shot of PB or T9 at the splines after you get the nut off and then grab the wheel at 12 and 6 and alternate 9 and 3 while you pull/wiggle back and forth and it will come off eventually.
    Shawner1974 likes this.
  8. Jul 26, 2021 at 12:23 AM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    Just doing this myself, steering wheel had been one tooth off since I did my rack two years ago, then I guess I overcorrected and adjusted by two teeth when I did my clockspring last year, because it's been one tooth off in the opposite direction since then.
    So, make sure to double check that your wheels are pointed straight after turning the wheel back and forth a few times, before buttoning everything up!
    SR-71A likes this.
  9. Jul 26, 2021 at 1:21 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Be sure to leave the nut on a couple turns so you don't smack yourself in the face with the steering wheel.
  10. Jul 26, 2021 at 8:25 AM
    victoriamatt
    Fort McMurray
    2011 TRD Access cab
    Good call, thought smacking myself with truck parts and tools often seems to be something I’m good at.
  11. Jul 26, 2021 at 8:27 AM
    victoriamatt
    Fort McMurray
    2011 TRD Access cab
    Cool thanks. I’ll probably ride the truck right up against the curb out front of my place so the wheels are arrow straight before I do it. Cheers
  12. Jul 26, 2021 at 9:14 AM
    Shawner1974
    Shawn
    CNY
    Once you have it straight, take a marker and put a line across the end of the shaft so you always know how to line it back up...ya never know when you'll need to do it again!
  13. Jul 26, 2021 at 9:18 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    There's a steering angle sensor that snaps to the back of the clock spring. Once the clock spring is out of the vehicle, it's easy to separate the sensor. It's indexed to lugs on the clock spring "rotor", which in turn is indexed to lugs on the back of the steering wheel.
    ChrisFix has an excellent video on this (the Prius parts are very similar to the Tacoma's). The steering angle sensor is visible at 11:05:
  14. Jul 26, 2021 at 12:23 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    :rofl:
  15. Jul 26, 2021 at 2:06 PM
    mk5
    SoCal
    '05 access cab 4x4
    Aaand... still crooked. I guess I'm half a tooth off? I'm taking it to an alignment shop so they can straighten it out at the tie rod ends. Waste of time and money I guess, but it bugs the heck out of me!
    Hope yours project is a success!
    Key-Rei likes this.
  16. Jul 30, 2021 at 8:41 AM
    victoriamatt
    Fort McMurray
    2011 TRD Access cab
    Thanks all for the great info, gonna do this ASAP. Does anyone know the current part number for the clockspring for vehicles with cruise and steering wheel mounted audio controls etc. (mines a 2011 access cab TRD off road)?
    when I did a parts search two different numbers were coming up:
    8430604080
    And
    84306 0E010
    as far as I can tell the second one is the updated version? Is that correct? Any info is much appreciated.
