Clock spring woopsie
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lefty9206, Feb 1, 2025.
  1. Feb 1, 2025 at 3:53 PM
    lefty9206
    lefty9206 [OP] Well-Known Member
    Jarrod
    2021 gray TRD off road
    None yet
    Today I was installing a new steering wheel on the truck and when pulling it I forgot to unplug one wire. When the steering wheel came off so did the clock spring. I was able to get a new one from the Toyota dealer nearby and put everything back together. I am now getting alerts like
    Headlight system malfunction
    Pre collision system malfunction
    Stability control system
    Lane departure alert malfunction
    anyone know what I could have missed and or how to fix these issues?
  2. Feb 1, 2025 at 4:02 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    I'm just surprised the clock has a spring.
    TXpro4X4 likes this.
  3. Feb 1, 2025 at 4:05 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Digital clocks have springs? :confused:
    Seriously, what is a clock spring?
    TXpro4X4 and 23MGM like this.
  4. Feb 1, 2025 at 4:06 PM
    chetterthecat
    chetterthecat Well-Known Member
    OR
    13 sport
    It is what makes the steering wheel buttons work, and the horn.
  5. Feb 1, 2025 at 4:11 PM
    Buck Henry
    I just looked it up, you learn something new every day! That little thing is integral with making all sorts of stuff operate properly including the air bag.
  6. Feb 1, 2025 at 4:12 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Toyota calls it the spiral cable.
  7. Feb 1, 2025 at 4:14 PM
    23MGM
    2023 TRD Off Road
    Note to self.. Don't install new steering wheel. I would never be able to fix all that stuff.
  8. Feb 1, 2025 at 4:17 PM
    lefty9206
    Jarrod
    None yet
    Turns out I’m a little bit dense and forgot a plug on the clock spring assembly. Plugged it back in and good as new. P.s. unplug everything if you change the steering wheel. Clock spring cost me $500
  9. Feb 1, 2025 at 4:22 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    It needs to be recalibrated. The steering wheel controls on my last truck quit working so I replaced the spiral cable/clock spring fairly easily. Still needed a shop to calibrate it.
    EDIT - missed your post above. That's great news, I wasn't so lucky.
    koditten likes this.
  10. Feb 1, 2025 at 4:24 PM
    lefty9206
    Jarrod
    None yet
    Hopefully the codes stay off and don’t pop up while I’m driving
    Jesse H[QUOTED] likes this.
  11. Feb 1, 2025 at 4:37 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Please elaborate on the calibration.
    I've replaced many clock springs in Toyota trucks and have never calibrated. What symptoms were you seeing?
  12. Feb 1, 2025 at 4:42 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Duly noted
  13. Feb 1, 2025 at 4:52 PM
    Jesse H
    Jesse
    Texas
    '22 TRD Pro 6MT
    This was on my previous Nissan Titan. Stability control was disabled and I didn't have the special tools to reset.
    koditten[QUOTED] likes this.
  14. Feb 1, 2025 at 4:53 PM
    koditten
    Kirk
    Central Michigan
    I hate these type of threads.
    Always takes me back to swapping out the clock spring, er, ribbon cable on my 2002 Tundra.
    I've removed the air bag, unscrewed the steering wheel nut, but that wheel won't come off. I'm beating on the back side with a 2 pound persuader and no joy.
    I remember that my dent puller kit has a bearing puller attachment.
    Sure enough, that bracket bolts right up to the steering wheel.
    I attach the dent puller and start doing the gentle slap. No joy. That wheel is still being stubborn.
    Ok, I'm sitting in the drivers seat and am getting pissed!
    I decide to give that puller handle " full beans"
    That wheel popped free, but not before the 3 pounds of slag iron dotted me in the forehead!
    I cut my mellon open and bled all over my shirt and gave myself a 20 hour headache!
    So, don't use the HF dent puller with the bearing puller attachment to pull your steering wheel!
    Learn from my mistake.
