clock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rockcrick, Jan 21, 2010.
  1. Jan 21, 2010 at 2:47 PM
    Rockcrick
    Rockcrick [OP] Member
    Sieg
    Tucson, Az
    07 TRD Sport 4wd
    Can't read the clock during the daytime because of the poor lighting. Anyone have any ideas for a solution?
    Sieg
  2. Jan 21, 2010 at 2:50 PM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    turn off your headlights and or parking lights. the clock with brighten up...
  3. Jan 21, 2010 at 3:49 PM
    Rockcrick
    Sieg
    Tucson, Az
    07 TRD Sport 4wd
    Don't have the headlights on during the day
  4. Jan 21, 2010 at 3:57 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    if you peel the face plastic off. it comes off pretty easy. then using 1000 grit you can sand the orange off on the inside surface. then polish it real good to get it clear again. the actual clock underneath is a Vacuum Florescent Display (think 1980s VCR) and glows a pretty bright light green color. Why did toyota use VFDs? I have no idea. the over head temp/compass display is also a VFD.
  5. Jan 21, 2010 at 5:13 PM
    Rockcrick
    Sieg
    Tucson, Az
    07 TRD Sport 4wd
    Will try it
    Thanks
