"clocking" warn m8000
Discussion in 'Off-Roading & Trails' started by BnbBlitz, Feb 24, 2014.
  1. Feb 24, 2014 at 12:38 PM
    BnbBlitz
    BnbBlitz [OP] Well-Known Member
    over the rainbow
    13 DCLB 4WD
    Anybody got any links or know how to? Need to rotate clutch lever to access it on my bumper.
  2. Feb 24, 2014 at 12:40 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 4x4> 03 SR5 4x4 total> 14 Crewmax TRD
    Had tons on the old Taco's.... new Tundra is pretty stock
    just loosen/remove the allen screws all the way around that hold the clutch lever side to the main housing and rotate the freespool housing- dont pull it out, only rotate!
    Align with the holes nearest to where you want the lever located and reinstall the allen screws. Done.
  3. Feb 24, 2014 at 12:44 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    & seal it up good.... them M8000's like to suck mud
  4. Feb 24, 2014 at 12:46 PM
    BnbBlitz
    over the rainbow
    13 DCLB 4WD
    That's all huh? Pretty easy... Thanks for the quick replies. Use some silicon on it? Tryin to get the bumper and winch in tonight.
  5. Feb 24, 2014 at 12:48 PM
    XXXX
    sKiP
    05 Prius
    don't rush it...
    look through my pictures for reference of the clocking and sealing.
    I'm currently rebuilding a M8000 now.
    silicone is better than nothing but you will need to let it breath somewhere if you seal it off. Ill be running a 2-3' extended breather.
  6. Feb 24, 2014 at 12:54 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    I just recently rebuilt my Warn 9.5XP, had my brother help and he posted a little video on it.
    Check out the video, we clocked the winch at the end when we put it back together. Starting 8:10 is where we clocked the winch. Hope that helps.
    http://www.youtube.com/watch?v=BADjA0t0g8I
  7. Feb 24, 2014 at 1:02 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    You only need to separate the housing about 1/4" to clock it. Don't just jerk it apart.
  8. Feb 24, 2014 at 1:11 PM
    Large
    Large Red
    That's a pretty informative video, I just kind of winged it when I did mine lol.
  9. Feb 24, 2014 at 1:12 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I know it was really easy with my SuperWinch. I can't imagine it being any harder with a Warn. Give'er!
  10. Feb 25, 2014 at 11:11 AM
    BnbBlitz
    over the rainbow
    13 DCLB 4WD
    Thanks for all the insight guys. Clocked it and mounted it up last night with the help of papa taco. TW all day!!
