Clockspring (Spiral Cable)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by onedivinetaco, Jul 22, 2015.
  1. Jul 22, 2015 at 4:48 PM
    onedivinetaco
    onedivinetaco [OP] Well-Known Member
    botolphston
    '05 dcsb 4x4
    Has anyone with steering wheel controls dealt with a busted clockspring? Apparently, there's a recall, but it does not include those with steering wheel controls. I ask because mine has broken. I have the infamous airbag light shining on my dashboard. My horn does not work, but my blinkers do. Looks like I'm about to fork over $200 plus for a new one. Any thoughts?
  2. Jul 23, 2015 at 7:28 AM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
  3. Jul 23, 2015 at 7:32 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    sound like all your problems may be from the cable reel
  4. Jul 23, 2015 at 8:06 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Are you sure the recall was only non wheel control people? I would call yota and confirm that...
    All i can say is that i changed my clockspring, bought a used OEM one on ebay and it works great. I think i only paid like 60 for mine... and it's real easy to change out. Just be safe and leave the battery disconnected for a good 20 mins or so before you start pulling it apart.
  5. Jul 24, 2015 at 4:15 PM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    Alternatives? Chinese knockoffs. Any problems?
  6. Jul 24, 2015 at 4:35 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    my Wife drives a 2006 RAV4 and she just got recall for this very item
  7. Jul 24, 2015 at 5:38 PM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    My truck is not covered, according to Toyota's recall site. Further research tells me this is the case with trucks with steering wheel controls.
  8. Jul 24, 2015 at 5:38 PM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    Steering wheel controls?
  9. Jul 27, 2015 at 6:49 AM
    ranger098
    Brian
    Minnesota
    I would stay away from a chinese one. your skull may thank you for it if you ever get in an accident.
  10. Jul 27, 2015 at 7:55 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    get a true Toyota OEM part from a toyota dealer
    you do not want to mess with a cheap clockspring.
    first off it will fail within 10,000 miles guaranteed
  11. Jul 27, 2015 at 4:16 PM
    Yoda's TRD
    David
    Haslett, MI
    no, not in her vehicle
  12. Jul 27, 2015 at 9:10 PM
    Xtopher
    Xtopher Active Member
    Pennsylvania
    08 Tacoma
    Subbed for interest.
    I'm in the same boat.
    In fact, my steering column was making a grinding noise since yesterday and I lost my horn today.
    I have a recall notice, but don't want to tie up the truck at the dealership...
    I've done airbag replacements before and may engage into it myself.
  13. Jul 28, 2015 at 12:19 AM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    I rear ended an asshole, while being an asshole, back in january. My clock spring was done after that. Horn doesn't work, but everything else on the steering wheel does. Radio controls and no airbag lights.
  14. Jul 28, 2015 at 1:36 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Same boat after doing some interior remodeling on the truck. Subed for updates.
  15. Jul 28, 2015 at 3:25 AM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    There are a bunch of threads on this, the solution is put in a new clockspring. Even complete instructions in a couple threads. Just do a bit of searching. The clockspring has a ribbon of wires in it and my experience was first failure of the lights on the steering wheel controls. Then cruise control, then the airbag light. I bought the part off eBay for $60. It looks and feels identical to the factory one that came out of the truck. Leads me to believe that the reason a lot of us are having problems is because Toyota used the cheap Chinese knock off from day one.
    Anyway, it's a quick fix and mine has been good for over 60,000 miles so far.
  16. Jul 28, 2015 at 7:09 AM
    ranger098
    Brian
    Minnesota
    Instead of subbing and waiting for an answer here, go to your toyotaowners.com site and see if you have any recalls on your truck. Itll tell you based on your vin. if you havent signed up on that site, you should its pretty tight. Theres even an app
    http://www.toyota.com/owners/
  17. Jul 28, 2015 at 10:53 PM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    Do you remember which one you bought from eBay? Obviously it's a knockoff as it runs $200-250 from the dealership.
  18. Jul 28, 2015 at 10:55 PM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    I'm assuming you haven't had your state inspection yet. Mine's due, thus I need to take care of this. It's an automatic failure.
