Clogged sprayer nozzle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cheesepreetza, Mar 20, 2014.
  1. Mar 20, 2014 at 7:46 PM
    cheesepreetza
    cheesepreetza [OP] Member
    Niagara region
    2016 Sr5 4x4 MGM
    LRT 3-2"
    When ever i spray the windshield, it sprays fine, then leaves a little dribble on the hood. Doesn't seem clogged, pressure seems to be enough. it just doesn't shut the flow off fast enough? no leaks on the other side of the hood, not clogged with wax. Anyone else have this problem? i have a super white 2 taco and to see little dribbles of bright blue washer fluid on the hood makes me sad panda.
    Just wondering if thats life with a taco or if its time for a replacement.
  2. Mar 20, 2014 at 8:54 PM
    luvium
    luvium Well-Known Member
    San Diego
    13 DCSB 4x4 TRD Offroad M.G
    Trimmed front flaps Extra D rings
    I use some stripped wire, just strip some # 14 or 16 stranded wire about a 1 inch. Twist a few of the strands together and clean out out the hole the water comes out, that is if there is a clog there, it might be clogged upstream.
    Good Luck
