*Closed* 20% Off Supercharger Group Buy 2nd Gen 4.0 Engine
Discussion in 'Closed Group Buys' started by big_jarv, Oct 6, 2016.
  1. Jan 5, 2017 at 4:35 PM
    #3041
    jsriolo
    jsriolo Well-Known Member
    Susquehanna, PA
    2015 TRD Off-Road V6 6-Speed 4x4 Access Cab
    I had slow leaks at both of my reservoir connections and tightening the clamps did not help me either. Before splicing in smaller hoses to fit on what are probably undersized reservoir hose nipples I decided to try some non hardening sealant. I drained the reservoir and hoses, scuffed up the reservoir nipples, cleaned reservoir/hoses, applied sealant to nipples, let it get tacky, reconnected hoses, let sealant cure for 24 hours, then tightened down the clamps. Probably overkill, but the leaks stopped.
    Camby[QUOTED] and Biscuits like this.
  2. Jan 5, 2017 at 6:09 PM
    #3042
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    I was thinking about going at it in similar fashion, but then the question aroused: how do I drain the reservoir? Havent come up with an answer yet. How did you do it?
  3. Jan 5, 2017 at 6:21 PM
    #3043
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Disconnect the hose on the pump. Gravity is an amazing science.
    gersus, Norton and loginfailed like this.
  4. Jan 5, 2017 at 6:35 PM
    #3044
    jsriolo
    Susquehanna, PA
    Disconnect the input hose on the pump. Also, MAKE SURE YOU DISCONNECT THE PUMP ELECTRICAL CONNECTOR. I did not initially and it randomly turned on while the system was dry. The other thread about failed pumps has me nervous about mine.
    Camby likes this.
  5. Jan 5, 2017 at 7:02 PM
    #3045
    Camby
    Brian
    Denver
    Could also disconnect the battery as well. Thanks for the heads up.
    loginfailed likes this.
  6. Jan 6, 2017 at 12:39 AM
    #3046
    moodywizard
    moodywizard Well-Known Member
    Looking to see if you guys are seeing the same thing as the chart I posted. Gadget said I shouldn't have 15:1 in boost so now I'm conflicted...
  7. Jan 6, 2017 at 1:28 AM
    #3047
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Look at the graph, I assume dynamometer test is done at full throttle/open loop.
    loginfailed[QUOTED] likes this.
  8. Jan 6, 2017 at 2:19 AM
    #3048
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine isn't like the graph at full throttle. At full throttle it goes straight to 11.
    gersus likes this.
  9. Jan 6, 2017 at 8:48 AM
    #3049
    FinnJ
    Finland
    That's what I like to gain too, impossible with Unichip.
  10. Jan 6, 2017 at 8:55 AM
    #3050
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Also my boost goes up to 8. :D
  11. Jan 6, 2017 at 9:47 AM
    #3051
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I haven't heard of any lean AFR issues with the TRD reflash. If anything, the TRD reflash causes the supercharged vehicle to run rich.
    My personal opinion is TRD purposely tuned their reflash to run rich as the potential consequences of rich AFR are not nearly as severe as running lean.
    Norton likes this.
  12. Jan 6, 2017 at 9:48 AM
    #3052
    Biscuits
    Can't wait to see what the boost is with our current temperatures here in Houston.
  13. Jan 6, 2017 at 10:17 AM
    #3053
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'll take a video this afternoon
    Biscuits likes this.
  14. Jan 6, 2017 at 10:22 AM
    #3054
    Biscuits
    Perhaps some track action this evening?
  15. Jan 6, 2017 at 10:34 AM
    #3055
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Nah, just a little boost as I burn out leaving the shop. I just noticed as I was heading out for lunch that have a little drive line vibration from around 0-20mph. I need to look into that.
  16. Jan 6, 2017 at 10:37 AM
    #3056
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    It lasted about 3yrs
    Sorry, almost 4yrs
  17. Jan 6, 2017 at 10:39 AM
    #3057
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    At -8F this morning the boost was bountiful!!!!!!!!
    Just got back from a trip to CO and the SC made a big difference passing in the mountains. Even with 285/75 17 (34X11.5) and no regear on the 6 spd. Looking forward to more upgrades, or fuel efficiency reduction mods...!
    Any one thought about running the exhaust out the bedside in front of the rear tire on the passenger side? Its hard to get my mind around the cost of these exhaust systems. Its metal pipe?!?!?!
    Ill order headers but I may have to learn how to build an exhaust.
  18. Jan 6, 2017 at 10:41 AM
    #3058
    inwood customs
    Dave
    U say fuel efficiency reduction mods, but i still get 21 highway.
    Your foot dictates alot of it.
    Torspd and Norton like this.
  19. Jan 6, 2017 at 10:48 AM
    #3059
    findingthingsout
    midwest
    21mpg? What elevation are you at? I always get much better efficiency when I am in the mountains. Otherwise I live near the Mississippi so ~600 ft above sea level. Its nice having the denser air but The best I get is ~15 weather city or highway. Have had one tank recently only get ~13mpg.
    Saving for a Tesla....
    gersus likes this.
  20. Jan 6, 2017 at 10:49 AM
    #3060
    inwood customs
    Dave
    Level to about 800
    Im on the central coast
    tacomavoyager likes this.
