*Closed* 20% Off Supercharger Group Buy 2nd Gen 4.0 Engine
Discussion in 'Closed Group Buys' started by big_jarv, Oct 6, 2016.
  1. Feb 27, 2017 at 12:05 PM
    #4101
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I changed the fuel pump to a Walbro 255. Maybe it's not needed. I don't have any evidence to prove one way or another. The sock on the stock pump was pretty nasty and clogged up though, so at least there is one benefit.
  2. Feb 27, 2017 at 12:06 PM
    #4102
    Boozng
    Boozng I don't know what I'm doing here.
    Dave
    626, 661, 323, 310, 760
    MGM DCSB TRD Sport 4x4 Supercharged
    FOX 2.5/2.0, Camburg UCAs, 33" BFGs, Pelfreybilt Armor
    GOTCHA! Great information! Thank you guys! @oliver1539, I'll be installing it hopefully within the coming month. Work has got me all tied up.
    oliver1539[QUOTED] likes this.
  3. Feb 27, 2017 at 12:07 PM
    #4103
    oliver1539
    oliver1539 Well-Known Member
    Kentucky
    2022 Pro/2016 Off Road
    Nice! Good luck with the install. You'll be happy with the results.
    Boozng[QUOTED] likes this.
  4. Feb 27, 2017 at 12:14 PM
    #4104
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    What difference would the new higher volume pump do, if the fuel pressure don't drop while full boost/rpms?
    Would I need one if I'm planning to install 2.85" pulley and headers? I have though that the stock pump would be fine.
  5. Feb 27, 2017 at 12:19 PM
    #4105
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    The facts and a graph were posted long ago and the thread got nuked. That person who offered up the info is most likely watching this thread. If they choose to voice anything about it, so be it... if not, ill respect that.
    I will not get into it by choice, and because i didnt get a chance to save the info before nuke.
    I will say, i suggest swapping the pump out tho.
    At the least it makes fuel filter accessible
    loginfailed and Torspd like this.
  6. Feb 27, 2017 at 12:22 PM
    #4106
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    It seems hit/miss on whether people need the higher output fuel pump when you make additional mods. There's probably a wide variability in actual fuel pump output from truck to truck.
  7. Feb 27, 2017 at 12:46 PM
    #4107
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It is all about duty cycle. Have an aged/clogged filter, that also puts a higher demand on the pump.
    Plain and simple here. 4Runners have a larger pump than Tacomas, both having 1GR's. They might have a higher liter per hour output.
    FJ's might have the same pump as the 4Runner.
    Assuming that the FJ has the same pump as the 4Runner, and that the larger pump equates to a higher flow volume, then we can theoretically say that the 4Runner/FJ fuel pumps can handle more engine hp than the Tacoma. Which means it'd take more hp to reach the max duty cycle of their fuel pumps.
    I only bring that up because the FJ members in here.
    Of recent, search through the TW forum, and you'll find many people complaining about pinging. Some have had reflashes done to their ecu's, and it helped a bit. Others have replaced their fuel pumps and never had a problem again. Some have done a ramp test and found that the OEM fuel pump fails the test, and is the reason the engine is pinging.
    If an OEM pump cannot handle the fuel requirements of a stock vehicle, then it certainly cannot for a boosted vehicle demanding more of it.
    Who cares though? $150 pump to save you from destroying your engine? It works, fine." "Never had a problem." To those, I ask, do you have the ability to datalog your fuel pressure, under load?
    Next, I ask, what is the Tacoma's fuel pump's liter per hour output? Being smaller than even a simple Walbro 255Lph (not to mention many of the others on the market) how can you safely say it can handle the increased flow requirements (HP) when you don't know its LPH output?
    Not to mention age, which equates to worn brushes, and hours of use, as well as the potential for a highly contaminated and clogged filter.
    Post up an LPH of the stock pumps, then we can accurately say what its safe capable HP is. Engine HP.
  8. Feb 27, 2017 at 12:48 PM
    #4108
    inwood customs
    Dave
    Nice to know about fjs!
    Well said
  9. Feb 27, 2017 at 12:52 PM
    #4109
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Toyota privies FJ's and 4Runners more than Tacomas.
    inwood customs likes this.
  10. Feb 27, 2017 at 1:24 PM
    #4110
    moodywizard
    moodywizard Well-Known Member
    Don't know about fj/4Runner pump being different/bigger. As said after replacing my fj pump truck does not go lean.. just adding more fuel to the fire haha also as another member posted an new fuel pump is only 150 from urd so it's the cheapest thing you can do to take something out of the problem equation either now or later down the road.
  11. Feb 27, 2017 at 2:14 PM
    #4111
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You're absolutely right on getting a fuel pump.
    @inwood customs I wasn't arguing the need for a pump by any means seeing as how I've replaced mine and I'm definitely an advocate for replacing them. I was merely disagreeing with the statement that you would see gains with the pump replacement. You keep referencing an unknown member with supposed graphs indicating what you are saying, and as i said, Id love to see those and gain some knowledge. But from my personal experience, The only thing that changed for me was I lost the flat spot in my power band which I'm 99% sure was my fuel pump maxing out. Did not notice a "faster take off" or "better acceleration " from it.
  12. Feb 27, 2017 at 2:34 PM
    #4112
    inwood customs
    Dave
    Never stated hp gains iirc.
    There was a lull from cruise to wot, thats what i thought i said. Taking out the lull TIME made for FASTER response/pickup. Possible fuel delivery issue
    The info that was posted from that other member showed fuel pressure drop off at high demand iirc.
    Not hp
    I dont remmeber saying anything about hp. If i did, please show me, and I'll happily edit that. I will NEVER hopefully slip into throwing out hp numbers without a dyno.
    I am not a butt dyno fan.
    I dont know if i mistyped, if your seeing what you want to see, or if somehow my wording is coming out wrong.
    Post 4121 i made the point i wasnt referring to hp
    loginfailed likes this.
  13. Feb 27, 2017 at 2:38 PM
    #4113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Had yours caused a lean out condition, Volcom, a bit extreme but still, then it would have been more of an obvious improvement. Being that your components were in a relatively good state, a noticeable difference was likely nill, as you mentioned.
    That graph and thread are gone. Physically deleted or blocked from member view, I do not know. The poster was warned about being banned because it would add to the fire, of the thread which I know you remember. People asked for pertinent data to quell the debate. Took a few months, with all parties involved, to make it happen. Made it happen. Unbiased, pure scientic data from a lab. Mods tore the thread down, almost immediately.
    The resource which they insulted....they have no idea what they lost. They were just wrapped up in all of the name calling in that thread, to see the value in they had.
    loginfailed and inwood customs like this.
  14. Feb 27, 2017 at 2:39 PM
    #4114
    inwood customs
    Dave
    4114 post... YOU said hp....not me.
  15. Feb 27, 2017 at 3:10 PM
    #4115
    VolcomTacoma
    Jeff
    NorCal
    You know what, instead of continuing another shit show here, I'll just drop it. I'm glad your you felt gains in your truck, thats what we're all here to do.
    *LAST COMMENT I SWEAR* That metaphor is inaccurate. The end.
  16. Feb 27, 2017 at 4:09 PM
    #4116
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  17. Feb 27, 2017 at 4:10 PM
    #4117
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  18. Feb 27, 2017 at 9:27 PM
    #4118
    bledsoe3
    bledsoe3 Well-Known Member
    Portland
    '15 DCLB Limited
    SnugTop, Air Lift bags, Bilstein 5100's up front, AAL in rear, 275/70/18 BFG AT TA KO2, URD TCAI, URD Cat Back
    Well shit! I threw my first code yesterday coming down the mountain. Made it almost three months since my install. Bank one and two, too lean. I don't remember code numbers. I installed a wideband AFR gauge a couple of weeks ago and it never leans out. Except when coasting down hill. It goes off the chart. I'm hoping the code came as a result of higher elevation and lots of coasting down hill. I had my neighbor clear the codes and I'll keep an eye on it.
  19. Feb 27, 2017 at 9:32 PM
    #4119
    SlapChop7
    SlapChop7 Well-Known Member
    Eastern NC
    2019 MGM DCSB OR 4x4
    What do you have to do to clear the codes?
  20. Feb 28, 2017 at 4:17 AM
    #4120
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Disconnect the battery for a few minutes, or have a OBDII tool. Such as a Scangauge II, or Ultragauge.
    Pavlik1988 likes this.
